Okay we need to get this thread back on track,,,so here's another vid
http://www.youtube.com/user/RadicalRacer41...l/2/f__DOB0XYMg
Eastern Creek
Pov 1
Lap times were rubbish,,,Duncan and I put 2nd hand engine in,,,so pussy footed all day and had major electrical problems,,,ran on battery power all day.
Neil.
Big ups to Neil for putting the camera in my car at our last sau day at OP GP
Not a problem Evil,,,pity I didn't straighten the camera properly. I have more vids for you. I'll bring them on one of those little usb plug in gizmo's to the trackday if I don't see you beforehand.
Neil.
Here you go 1.15.88 OP GP Sept 2009 Supersprint
R33 Road Rego'd
Yes I know about the sound issues enjoy
Great vids Stuart. That i-race stuff is a bit crazy. And the 15.x at OPGP was great, nice work mate.
good driving dave....its bloody hard work getting past a car that's quicker in a straight line. good save on lap 6 as well
stu that irace had a hell of a variation in speeds...and did that ute clip you or was that just the ripple strip? he really should never have turned in there
Cool vids as usual Ash,,,the reverse grid one in the rain was most entertaining.
I put my pov1 in Rod Marklands HR31 at the muscle car masters. His starting is really bad because his launch handbrake wasn't releasing properly.
Neil.
Nice video Neil.
That engine sounds awesome! what is it a RB20?
Looks a bit laggy? Once he nails the start and sorts the powerdown coming onto the straight it will be really quick.
Ash
sure is...that's Markland's Gibson R31 Group A car...outrageous in a straight line against the group C "big banger" v8s isn't it....just 2l pushing it along.
Yep different - cant blame the ute for not using his mirror - he didnt have one, check out right d/s - I faired better than someone else - did just touch bar - scratch only, but yep, spot on, did have to jump ripple strip as well. I was a bit keen, had the same drama's passing it earlier in the same race (12 lapper).
Didn't matter - reverse grid with 50 second penalty, won race on last corner!!
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
