http://www.youtube.com/watch?v=5lgo4Tihfy4
A run from today's wet hillclimb, the first round of the 2010 series. Also first drive of my road reg 180SX, so I'm really just feeling the car out at this stage. The plan is to push a bit harder tomorrow...
I do rate the climate controlled comfort while sitting in the starting queue! hehe
yeah, diff gears are somewhere around 4.4, but its only an R180 currently. I want to get an R200 in there before I destroy this poor little thing!
The front end is a real compromise at the moment. I couldn't source new 5 stud hubs in time so last weekend I reverted to the standard S13 4 stud hubs and brakes, and borrowed a set of wheels and tyres off a mate just so i could get out there to collect a few points in the series. Suffered with plough understeer all weekend on the 5yo 2nd hand front tyres though. You can just about make out the chatter from the plough understeer it had in turn 1 in that vid. But even so, it led the class in the wet runs, but when it dried out a bit on Sunday (still wet in the tree covered loops at the top of the hills) I got my arse whopped by a little Triumph GT6 on Avon hillclimb slicks. Hopefully it will be a different story when i get my proper front end in and a new set of rubber. Thinking either RE55S WT compound or a set of slicks... Still managed 2nd in class, so not too bad for a first outing. There's a fair few suspension changes from the old car but hard to make any calls on those changes running on mis-matched rubber, and in those very changeable conditions.
nah, I better not wear out old mate's front tyres before I hand them back!
Need to get the hubs, and either another set of wheels or flare the rear gaurds like the old car before it gets back on the track. I might have to find my sledgehammer!
I've never used a gaurd roller, or even seen them used for that matter. Are they just for lipping the edges or can they actually form a flare? I need about 2" to fit the rears on. The panel work is pretty strong back there too...
buying wheels with the right offset would be the easy way out, but I like the Regas
Sledgehammer it is! If it all goes pear shaped there's always widebody gaurds! lol
Here's Sunday's runs. The first one is a shocker- so bad I gave up! 2nd was my fastest I think and the other two are a couple of tenths slower.
http://www.youtube.com/watch?v=xLDhEUlorRo
What is afforadle to some ... :) My mate has a flash Sony camera, he used it for when he was doign contract work for Vodafone and was broadcasting fron the T888 pits on race weekends. ITs a good thing, but about 3k from memory. He used to tell me that you need a certain prefix, which effectively means broadcast quality
Question for those in the know,
What cameras do they use for those slow motion shots on the TV and is there something affordable that will do a decent job for the everyday person?
Matt
TV cameras are really expensive. The slow motion versions are Not really in reach of everyday person.
I have a Casio Exlim FC-100 which is a point and shoot camera that does a decent job on video. On these cameras the slower you go the more resolution you loose. @ 210 fps (about 7x slow motion) you get about 480 x 360. It does also shoot excellent quality 720p hd, however it does not allow zoom when in video mode (my only complaint).
There is a new model coming out soon that is supposed to have better iso ratings (e.g. better at shooting high speed in low light). But unfortuantely there aren't that many models of cameras/video cameras the offer better resolution and high speed. I'd love a 720p high speed, but none are out yet at the consumer level.
I ordered my from HK ebay - digitalrev. Was pleased showed up in about a week and had extra battery and some other goodies thrown in. I think you can pick one up for around $300 now.
See some of my videos on youtube for the slow motion video.
Lakeside is such a cool track. Would love to see Tony Crotchrot throw some money at the place and bring the V8s back...hang on he screws venues for money, doesnt invest in them :)
Won't happen, conditions of use see to that. Bugger the once a year V8's anyway, some fast cars get out there and its all free to spectate.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
