thanks heaps chris :] yea pretty happy with the day, the time of 58.05 on natsoft is incorrect as my GPS and video both agree with each other. old fella mustv been too quick pushing the button.
also on lap 3 of the 2nd vid split times indicate i was on course for a 58.18 for until i made the mistake, bugger.
Edited by scooby36
Ive always known Lakeside to be a high a speed circuit but thats the first time ive seen the speedo on a vid too, thanks Callum!
and just saw natsoft too - fastest lap of the meet - top work!
Do you not watch my vids Chris? lol :P
..... above on a very worn set of O3G's. Note the coner speed difference especially on the turn onto the straight Cal!
Edited by Marlin
thanks heaps ben, good to see ya yesterday.
watching mine afterwards i am relying too much on safe understeer and its probably costing me time and killing my front tyres. i will adjust the balance for next time.
looks like the aero helps my mid corner speed a fair bit compared to yours.. weights being about the same 1190 no driver? and i have a lot of tyre too, 235/255
It's a fantastic little track Chris, you need to find the time to get up here mate :)
I'm 1240 no driver from memory when I last corner weighted it.
Mine's screaming for a front splitter, it improved with undertray, splitter hopefully a step better. If I can get the front to tie up a bit better I can wind some wing back in on the rear.
Love it ^^ , looks like it wants to lift the tyres off the ground under hard brakes!
and man toffy the amount of lock you need to wind in to turn that thing, im getting tired just watching !
explain the gearbox.. simple 3 speed yea? looks fuggin fun but hard work!
yeah three speed (think of starting in 2nd and that's about it) , i need to adjust it a lil better so i don't have to do a z to go from first to second :blush:
Toffy from 8:00 onward is madness. Cars all over the place.
yeah that whole race was like that, it got worse in memory , the top 8 cars ar within 5 hundredths of a second of each other in memory (although it doesn't seem it in the vid ). it all comes down to qualify/start line take off pretty much
Edited by toffy
They are nice vids. I cant help but think that the footage you are getting is better then what I am getting out of my Radcam...will have to try some of the settings on my thing.
Also, do you know where the timing beacon was located on the weekend, by my vids I was doing 1:07-1:08s on the short track, but I suspect I was backing off after the finish line and I suspect the beacon was on the back straight now that they have me 6 seconds slower?
The timing was screwed up on the short track. Winton timing gave me a 1.10.x, racechrono gave me a 1.08.x and video gave me a 1.08.x
The long track timing was working correctly though.
As you say the beacon may have been somewhere else for the short track....?
I use the Go Pro HD's in centre metered mode all the time. This means that it takes light readings from the centre of the video and not from inside the car.
I'm cutting the vision of mine at the moment, but this is in my brothers car (white 33 gtst).
Got a couple pieces of lightning in the video, crazy stuff.
Watch out Stagea it's coming for you!
Yeh, its doing everything pretty well. I just need more seat time and need to get the general balance back to how it used to be which is to make it a bit pointier so i can drive it a little more on the throttle mid corner and get some better drive out of corners.
What is done to the front end of your car? It seems to need more steering angle then mine...but that could be tyres?
Good vids guys :thumbsup:
Great to see the silver beast in action Troy. As for Richos steering angles...maybe its a 33 thing as mine seems to require a fair bit (will have to check my winton footage to compare) so much so that it feels uncomfortable to keep my hands on the steering wheel in the same positions
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
