An old set of Pirelli slicks 305x680x18
Theres just over 2 seconds to be gained on new 305x645x18 slicks at Sandown if I can do my part.
The car was setup for Phillip Island hence the taller profile tyres.
^ thanks enjoyed that! would love some details on the car. are you commin to the Dec Sandown day?
Thanks
I would like to come if I can make it.
Car Details
R32 GTR setup for track use
Hollinger
RB26 430 AWKW
E85
MOTEC
1290KG no driver or fuel
List goes on and on LOL
Thanks for watching
  • 3 weeks later...
that's excellent....and I've finally seen someone better at cutting corners than an evo driver too :P
looks like you were at the top of top gear for a while about 9min, how fast does it go? looks farking unstable to be going that quick, especially over that jump, it would take some balls. And I love how quick you get to run through reasonably closed forest.
BTW gay horn ....you need to change it to a set of air horns that play a tune. No wonder the other cars were ignoring it
lol yeah I said he needs the 130db air horn from the truck shop, but that breaks the noise restriction limits
the Polaris that started in front of us cut them better then us, which worked out good for us, as they made a new track we went passed him
we normally topped out 3rd along that straight once into 4th and its a 5 speed straight gate geared for 220km at 7000rpm with 35s, it's a VQ35HR ( class restriction of 3500cc ) with a 8500 rev limit
that track was cut down because the rest of the track made that part look like we where running around on a cricket pitch, that was the first time a national round was held at that track and the first national round my brother had done in that car so he was taking it slow to get use to the car, it's to bad the GoPro went flat cause it got a fare bit faster
we left the line in 47th place ( first national event and no prolog due to weather and shit/dangerous original track ) with 15 second gap between cars and where 16th across it with 9th outright and 2nd in class
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
    • Hi everyone, just looking to see what's available in the GTR seat options, testing the waters on what's available. Wanting a driver's seat to replace my old school OG jap race seat, going to re-register the car so need a factory seat. Prices currently seem to go from $300 to $2k for a driver's seat. What's options are there, that's good condition and actually a realistic price? Located Brisbane. Thanks
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
