Bernie and his kunt daughters can eat the carrot from my cable! I was pissed off when I heard about the camera gig. That wasnt explained at time of entry ... it helped me hide the pain of missing out.
Portimao was a great track. Better than Estoril and maybe just better than Zandvoort. It has plenty going on to keep you confused. It was harder for me to learn than any other track I have driven...though I suspect Bathurst will be a head warp for me as well. The lil R300 was so hard to drive straight....after some laps of throwing it around and losing it every secon lap the lasting fun was trying to drive it straight and get drive out of corners
If Iberia goes ahead again next year I am going to have to get the R32 over for it. Two days at Portimao in teh R32 would be epic. Would be a great track for a decent powered rwd Skyline
Hey Guys,
im always on here checking out peoples in car videos for motivation but have never pulled my finger out to put one of my own up.
This a 88 hr31 skyline that my brother and i race at supersprints and practice days. We managed a 1:07.03 with poor rear traction at the new south circuit at eastern creek.
(Note: dampers were wound all the way to hard rather than soft last track day so you can see its abit taily! has since been rectifyed!)
Has a Rb25 engine and gearbox, K sport big brakes and coilover, motec and fuel system plus HEAPS more.
Hope you enjoy the video! Cant get the youtube link to show the video here... just have to click the link
Edited by WAG.00N
Cheers! It should be abit neater next time!
I figured I'd smell the fuel leak before she ignites and if I don't it would e too late anyhow. But I like to keep it neat and tidy looking, even though I only drive it to the track.
The Marshall's definatly noticed a skyline sliding heaps.
Edited by WAG.00N
Alex, I saw you there on the ARDC practice day. Your car looks and sounds amazing :yes:
I was in the white Evo 6 and the good wife in the green Focus RS.
Thanks mate! Had a good day! We were watching you lift your inside rear wheel well off the ground every lap!
Quick question. I noticed your wife was in another group. We were In L2S group, what licence does she have?
Me and my brother both drive our car and paid 105 each. We asked the guys at registration if we could go in seperate groups so we wouldnt hve to share the L2S session but they were just rude an gave me no reason but "no you can't" and that you can't go in that group with a L2S licence.
So we had to share the session for the same money. Was not impressed cause it never been like that at previous practice days.
Any info would be good cause I want to make sure it doesn't happen again.
Cheers
on the weekend the WA CAMS Speed Event Series did a super sprint in support of the ARC rally guys on there Busselton Super Special Stage.
My day started ok but on my 2nd run i found out for real that concrete always wins.
Vid:
fixed it up and went out and finished the day.
Edited by racegtst
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
