Hi Jess that would be good to see you drop past one day and say hi always good to see your smile
Yeah think I will!! But when are you going to come racing again?? I'm sure the GTR needs some cobwebs swept away :banana: You would get a kick out of MRA!!!
ya i didnt compile it with sound ( not on purpose ) . it took 1'ish hours to compile on the notebook, so haven't been bothered to do it again.
plus the transition and some of the cut footage didnt render in smoothly, not really sure why. stupid premiere.
  • 1 month later...
I asked the same question in the Vic section with no response as yet.....advice for youtube noob.
I have a vid that has an aspect ration of 720x576 yet when I upload it it appears as 4:3. How do I keep the aspect ration the same as the original file?
I found it to be such a nightmare when I first tried to edit with moviemaker and then upload. It would come up with green lines top and bottom, or be 4:3. Even one of those videos above is off. The reason the other one works well is because it wasn't edited at all, just a straight upload.
I asked the same questions mate: http://www.skylinesaustralia.com/forums/Ca...ne#entry4752760
Thanks Dane. The thing is that I have edited the clips using windows movie maker with no dramas. I can play the edited clips and the aspect ratio is spot on. However when I uploaded these clips to youtube they have been squashed to a 4:3 ratio.
Ok it appears there is a diff between uploading wmv and avi files. I managed to upload the avi's without youtube changing the aspect ratio.....
Two of my fastest runs at Haunted Hills over the weekend:
I was experiencing exactly the same thing, it was only when uploading them that they were changed by Youtube.
I was then havign to convert them to .avi's using another program, then upload them. Pain in the arse :down:
Speaking of things being painfull. I bought a new Canon SD card video camera. It takes good videos but appears to use a .mov file format which my dodgy Microsoft video editing software fails to recognise. Any ideas what I can use instead?
I can't remember what it's called, and don;t have it on this new computer, but if you look up file converting software you'll find some that can convert it from .mov to .avi, then you should be ok.
I bought "Pinnacle Studio", wasn't too expensive and unlike windows movie maker runs all the input and output formats you would want (WMM does not support HD or widescreen on win64). Also easy to use.
The GoPro HD I recently got outputs in mp4 format.
I use Xilisoft HD Video Converter to convert them to regular mpg then use MPEG-VCR to cut out the bits I dont want then convert them back into mp4. The end result after the cutting and converting is a file that is about 10% of the original size.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
