btw, in some later sections I was getting close to just a slight lift at the kink and flat out under the bridge and over the crest into Hungry. if that doesnt make you feel alive I dont know what will.
Quite a few one end drive road cars go flat out through the kink at over 200kph, R35 should be what 20kph faster. Something to aim for.
  • 3 weeks later...
lakeside today:
59.72 beat my semi-slick PB by just 0.15. Was driving like an old mole out there though. These new tyres have alot more than that in them. 6 months away from a circuit has taken the edge off a bit, and I never really felt comfortable in the car today. Will have to go back again soon to get back up to speed I think.
Edited by hrd-hr30
yeah I have been going through there at 225kph with a dab of the brakes flat out I estimate would be around 235kph or so, on the 3-4 day old slicks it was starting to move around a bit which wasnt a comfortable feeling at that speed.
new slicks and some aero and 245 is the goal!
lakeside today:
what tyres and size Harry?
Got the new Federal FZ201 semi slick. 235/45 & 255/40 R17. Wider rear changed the balance of the car again. I should have learnt by now, but will make some changes before the next Lakeside Open Sprint in a couple of weeks.
I just entered the luxo barge Aristo in the Street Sprints on Sunday, just for laughs. It might go OK - its basically a 4 door Supra, but with a slushbox... I think the biggest challenge will be remaining in the nice comfy leather seat.
now for some sounds of silence... my daily driver Aristo at Lakeside.
WARNING: this footage may distress some viewers. Particularly Evo owners
Session 2: chasing 6spd TT Supra and passing Evo 10
Session 3: chasing Porsche and Evo 7-9 (all look the same to me)
Stock boost, run turbos in parellel instead of sequential, factory option Bilstein suspension, stock brakes - need new front rotors now. Warped them in the 1st session and you can see the vibration through the car under brakes! Has trans cooler and FMIC. Compliance cat, 3" mid pipe to twin 2.5" and stock rear mufflers. 62.6 best lap. vMax 193.4kph thanks to the HKS SLD :)
hehe, got a bit excited...
bolted the wheels from the 180SX on, so it was on the Federal FZ201's.
The thing actaully handled very well with similar cornering speeds and the same lateral G as the 180SX. Would be alot easier to drive it that hard with a decent seat though.
The way the Aristo rode the bumps I'm thinking about softening the 180SX up a bit... again...
How did the auto handle the day Harry?
Ive always been wary of taking the Soarer out to the track because of that
Actually how did the car pull up?
As you probably know the Soarer and Aristo/Supra are basically the same, just the motors and number of doors differ
I've got a big transmission cooler on it. Just the largest Davies Craig one from Supercheap. They're about $130 and take half an hour to install. Temps on the IN hose were just under 70deg and OUT hose was under 50deg after each run. The auto never made any complaints on the track.
Engine temps were getting up around 100deg towards the end of the session, which is within normal operating range, and came straight down as soon as you back off. No problem there. Its still got the standard hydraulic engine fan.
Standard brakes, pads and fluid were fine apart from the old (and probably a bit thin) rotors warping in the first session. Its pretty common on OEM Toyota rotors from my experience. The JZA80 Supra I had with exactly the same brakes did the same thing. Changed to aftermarket discs and no problem.
Whack a trans cooler on the soarer and have some fun. If its in good mechanical order, it should be fine.
hmmm... graphed speed and lateral G from the 180 on Thursday and Aristo yesterday:
(lateral G x50 to get it to show up on the graph, so 50 is 1G. Peak for both cars is 1.2G
It wasn't the fastest lap int he 180SX - the iPhone didn't want to stay on the windscreen inthe 180, so I've only got data from the 1st session. This lap was a 60.5.
The automatic Aristo looses out in accelleration, but it looks like it was at least a match for the 180 in Eastern Loop and the last turn, if not a touch faster... Caught the 180 a bit under the bridge too. I suspect I lifted on that lap in the 180, or it got a bit sideways and scrubbed the speed off.
Aristo felt much easier to drive through Carousell, under the bridge and through the kink. Carousell's double apexer, the Aristo just goes where you want it to, no fuss at all. The 180 is always puts up a fight to get it back into the second apex. In the fast corners under the bridge and the kink, the 180 is pretty nervous on the bumps. Aristo walked over them with no fuss at all. Might be interesting with a bit more boost in the Aristo and maybe without the heavy electric seats! hehe
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
