  • 4 weeks later...
  • 3 months later...
Well after a long wait, and a lot of patience i finally took the plunge and attempted to fit a 34 GTR exhaust (Impul) with stock GTR cat to my GTT split dump/front pipe from JJR.
Several hours and a broken turbo stud later and its on, but...
I can now confirm that a gtr catback (at least the one i bought) does NOT bolt up to a gtt, it is infact too long! its about 3/4's the length of the cat too long, so about 8-10inches
So now as it sits, i have my JJR 3" front/dump, mated up to the mid section of the cat back, minus the cat, with about a 8-10inch piece of custom pipe to make up the difference in length, which then joins to the end pipes/muffler
Further more, when i get a new cat, the system will no doubt need a little chopping and changing to accomodate the size, assuming its longer than what is already there.
So no, a gtr catback will not bolt up to a gtt without a little customization.
Big thanks to all the guys at Al's Race fab and mechanical, worked tirelessly through the night to get me back on the road
the hangars were ok, a little tight toward the back of the end pipe,
The Impul gtr exhaust sat perfectly in the centre of the cut out section in the rear bar, nicely tucked up under the car.
The stock gtr cat would bolt up to the 3" dump/front pipe i got from JJR, but i dont know how it would go with a stock gtt cat, im not sure if the flanges would be on the same angles
RusH, you know you could have just bought a R34 GTT exhaust system... :D
Straight bolt on fit and I am sure IMPUL make one if not other Japanese brands make exhaust for the R34 GTT.
RusH, you know you could have just bought a R34 GTT exhaust system... :ermm:
i spent $550 on a full 3" turbo back system... im fine with the customized way :), jumped on a good opportunity when it presented itself and got the full system at a great price (installed for free as a bit of a trade off)
I see...
That sir, is a great deal! :)
Well as long as it worked out fine it's all good.
I see...
That sir, is a great deal! :D
:D sure is
Will be getting the mid muffler removed shortly to increase the noise and putting in a metal cat as well
:D sure is
You want more noise..?
Brisbane must be pretty lenient...
Haha!!
Haha!!
well i have to say, with the oval tip muffler and the mid muffler, the exhaust is not much louder than stock, it would be great for a stealth application, but id like a little more of that RB growl :)
Yeah true, I too just bough a Veilside Oval shape muffler (Cat back) and before it was on a R32 GTR, heavily modified and it sounded quite, so it should sound similar to my stock cat back, but just a tad louder.
BTW, GTR exhaust's have twin out lets into one - molds into the front pipe.
So what did you have to do to make it fit? Block off one of the inlets on the exhaust? Cut it off? Block it off?
Well mine is a cat back, so its only a single pipe from the cat section back, so it was just a matter of lining it up and bolting it in, a new piece of pipe was used to make up the extra 8-10inches after removing the cat.
That is all mated up to the GTT bellmouth dump/front pipe
i spent $550 on a full 3" turbo back system... im fine with the customized way :(, jumped on a good opportunity when it presented itself and got the full system at a great price (installed for free as a bit of a trade off)
So did you buy a full exhaust or just a cat back... :P
I can see a pic in your avatar, got any more?
^^Looks great RusH!
The fitting looks nice and neat too.
Good exhaust flow for sure.
Thanks dude,
Its tucked in pretty good, and has decent clearance, so it shouldnt cause problems when i get some coilovers on, and it doesnt rattle or move about either, so all in all im pretty happy :P
Wonder how well an R34 GTR exhaust would go on an R34 GT-T sedan then, if it's too long for the coupe.... There's an R34 GTR cat-back exhaust I'm eyeing off at the moment - but I don't want to go to too much effort modifying it to fit.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
