Hey all,
I posted in another thread about this, but would like everyone's opinion on what could be wrong...
I'm not exactly a wizz at this whole mechanical side of life, so can anyone please explain to me what is wrong, if anything? I did an ECU fault test about 2 weeks ago on my R32 5sp RB20DET, and saw that the Knock Sensor code was coming up (from memory it's 3 long flashes, and 4 short flashes). When the car is cold, it is very hard to start (have to pump accelerator repeatedly) and the oil pressure sits under 4 on the dash nearly at all times... It never stalls when i push the clutch in, and never has yet. It also feels like the car isn't moving as quickly as it should. (EG, in every gear, second especially, it doesn't feel as free moving as it should...)
Does this mean i've done a main bearing, blown the bottom end or am i just paranoid?
Thanks. Matt.
https://www.sau.com.au/forums/topic/27016-rb20det-knocking-help-please/
Give it a basic service.
I suggest :
- clean AFM (and air filter/or change element whatever is applicable)
- Put in new spark plugs (read cheapies - copper)
- Change oil and filter
You dont actually state that you can hear a knock from the engine.
Im changing the oil in my car this weekend, i would expect as was the case with my old SR20, that once it gets a gut of fresh/thin oil if a knock is present then it will be more evident once i have done an oil change. Incidentally this will be the 3rd oil change since i first noticed noise 9,500kms ago.
Im now thinking its perhaps some ancillary noise or perhaps top end noise on startup in my case.
matt,
i had htis code flash up when i did an ECU diagnostics and the reason it comes up is that there is some sort of fault with the ECU getting readings from the knock sensor
in my case one of the 2 knock sensor's was not plugged in!
it could aslo be that the sensor if faulty or just screwed.
it takes 2 minutes to check them: just stand over th battery looking towards the throttle body. If you hold a torch and look through the intake runners of cylinders 1 and 2 then you should see a little green sensor with a white plug plugged in. It is right under the intake plenum and attached to the block (may be hard to see). there is also another snesor between runners 5 and 6. have a look. in my case the plug's were hanging and not into the sensor... i had many of the symptoms you mention above of which most went away after i put the plug back in!
cheers,
Warren
  • 1 month later...
Mine is suffering from pretty much the same symtoms - cold starts and a bit of ping (rattle sort of noise when at higher revs) - when its hot, i am running too much boost on a stock cooler for this sort of weather me thinks...
i am thinking the fuel pump is on its way out, is there anyway to check it? Can somebody send me the diagnostic codes and how to check it?
[email protected]
[email protected]
call me on 0411 878 961 and I'll talk ya through it if you like./.
My 32 has gradually been getting harder to start since i got it. I have to pump the accelerator and will only go on the second turn of the key.
Is there a simple explanation for this?
My oil and filter was changed not long ago. Plugs are around 7000km mark.
Regards,
Scott
Hey my R32 is also beginning to get harder to start, it only happens in the morning when the car is dead cold, it starts first turn of the key but sits at 300rpm or less and almost stalls unless I tap the accelerator, at which point it roars into life...well not really - it just starts idling properly! Sticky AAC valve perhaps?
I'd love to know the actual cause of this as well, it's only a recent thing on mine, and as with MM2Death - mine has regular oil changes and I just checked the plugs.
thanx,
Dave.
Hey Dr_Drift,
Thanx for that, if all goes to plan I should be bringing the car into BMT early next year to get some mods installed/car dynoed, so that'd be the best time to get you to check it.
BTW, you worked on my friends car - the purple DR30, I drove him down to pick it up. The car is running really well, I can't believe how quick it is! Once it's complied & on the road (soonish) it's definitely gonna scare some people!!! ;-)
cya!
RaseR - Small world :D I love FJ's they're quite an amazing motor.... The one i was chasing fell through so I'm sticking an SR20 in my Datto 1600!!!
Look forward to seeing that FJ for some mods soon :cheers:
Doc.
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
