Hey Dr_Drift,
Mutterings about rebuilt motors and microtech ecus give me the feeling you'll be seeing that FJ powered 'line again in not too long!! :D
An SR20 powered Datto 1600?! NIIIICE! Decided against the CA18 u mentioned when we came in then?
Just tried the ECU diagnostic test on my R32 btw...the 'All OK' code 55 flashed up so could it possibly be blocked injectors as WazR32GTSt suggested? Finally do BMT clean injectors, if so - how much approx? If not, know of anywhere I can get it done?
Thanx!
MM2death - Do a search on 'diagnostic' should find the answers there.... If not I'll type it out for ya...
ECU diagnostic
Switch on the ignition, but don't start. The LED on the ECU will be glowing.
Turn the selector screw clockwise all the way (gently!) If your ECU doesn't have a diagnostic mode screw, use the diagnostic connector to enter the diagnostics mode.
For one LED ECU's: wait a couple of seconds, and turn the screw back counter-clockwise, the ECU is now in mode 2.
Note - the engine check light on the dash will mirror the LED on the computer.
The ECU's on most R32's have one LED, long flash = first digit, short flash = second digit, eg long, long, short = code 21.
Codes:
11 Crankshaft position sensor
12 MAF sensor circuit
13 Coolent temperature circuit
14 Vehicle speed sensor circuit
21 Ignition circuit
31 ECU
34 Knock sensor
43 Throttle position circuit
45 Injector leak
51 Ignition circuit
54 Auto signal to ECU
55 All OK
Turn the ignition off to put the ECU back to normal.
Is this correct? I have never done this before.
Thanks,
Scott
Hey MM2Death,
That's the procedure I used to test my R32 GTS-t, to get to the selecter/LED you have to actually unscrew the ecu from the car body and remove it from its mounting location as it is on the side you can't see (typical!)
There is however an easier way, which I tried first and didn't realise till later was actually working....If you pull the fuse box lid and look right up into the top of it, you'll see the Consult connecter. There are two pins you can short out with a bit of wire for two seconds then when you remove the wire it will put the ecu into diagnostic mode, check this link:
http://www.powerlink.co.nz/~graeme/faq/15.html
I found on my R32 however that the Consult connecter was rotated 180 degrees as compared to the one shown in the link above, with the two pins being on the top right hand corner....wierd. The 'cat temperature light' will flash out the trouble codes - I expected the ECU light to do this, when I saw the cat light flashing at first it didn't click what it was doing - LOL!
Hope this helps,
Dave.
Hey Scott,
No probs man - Another cool thing to note is that upon completion of the ECU diagnostics (ie. turning off the ignition), the ECU is also reset. This is cool because you don't lose your radio stations etc as you do when you disconnect the battery and no need to remove interior panels (well except the fuse panel....) and no having to fiddle with the ecu like the usual diagnostic method.
Post your ecu diagnostic results when you have time! Mine came up fine (Code 55), but then again my cold starting issues are hardly what you'd call bad as yet.
Dave.
OK i've just done it. Code 55 is what i got. So that doesn't tell me much about my problem with cold starting...lol
Oh and my connector was in the same position as yours. The terminals to short are in the top right.
One more thing, i just noticed that my fuse panel ain't full...a few were missing....is that normal?
Regards,
Scott
Hey Scott,
Interesting - the connector in that diagram must've been for an R33. Mine has 4 empty fuse holders on the LHS of the panel and a couple missing along the bottom. My theory is that these are just extras for features either not present in the car or not even implemented.
But no, it doesn't help much with the cold starting issues at all, it would seem that the diagnostic mode really doesn't supply enough information about the vehicles sensors for this kind of problem, it was worth a try though!
Check this, interrogating the consult port using a laptop computer.....No official skyline version as yet though:
http://300zx-twinturbo.com/conzult/
Looks so cool, you can view all the detailed sensor data in real-time, apparently it unofficially works on other Nissans but even if it did work - it costs $600AUD....Probably more then taking the car to be fixed!! :)
cya,
Dave.
firstly: i just did the diag. and got code 54. Now my car is a manual but it has an Auto ECU (1/2 cut), i don't now if this would affect my car or not but. My 'line is sluggish but when warm (cold start issues), but when warm runs fine till start boost at 5000rpm (3037s) then it just
bangs and kinda backfires and doesn't go anywhere. I just put this down to a nearly stuffed motor as is pisses oil out of the breathers for the tappet covers. But occasionally it runs fine (full boost) in a couple of gears, usually at cold amb. temps.
Secondly: I use to work at a nissan dealership, and the nissan consult II does work with the R32 skyline at least.
Hey guys,
Just a quick update on the original problem, the car is running SO much better now, but i am still having the cold start problem, and now it's getting worse. It takes at least 4 turns of the key and constant pumping of the gas to get her started. I'm going to try changing the spark plugs, if that doesn't work, i'll try the fuel pump (it's standard, so it needs doing anyway).
And if that does nothing, i'll try the started motor... (Again, i don't know much about engines, but is there a starter motor? I heard someone talk about it in their VN commie...)
I'll keep you all posted
Matt.
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
