Yes its official. My Cefiro is POSSESSED! :P
Indicators dont work: in the process of fixing that...
Cluster gauges dont work: fixed (loose plugs at ecu)
Interior light: works sometimes but not lately
Wiper aways intermediate and stops half way: fixed (loose plug at ECU)
Almost stalls at idle after a good flogging: ???
Almost stalls when turning steering wheel at idle or parking: ???
No REV LIMITER: ECU decides to forget this feature after many times set by my tuner
And most of all... Hates to idle: no vacuum leaks (probably something to do with the tune or cold start valve)
Mods List:
RB20DET Stock bottom end
Pod
Garrett GT30XX
Hi flowed exhaust manifold
3inch exhaust
3inch dump pipe
FMIC
Turbosmart BOV
ARP head studs
Cometic Multi layer head gasket
Rebuilt head
Unknown cam shafts
Adjustable cam gears
Triple core radiatior
Nismo raditator cap
Nismo 600cc injectors
GTR fuel pump
Turbosmart fuel pres reg
Braided lines to the turbo
Custom head oil drain line
19 row oil cooler and filter relocation
MicroTech LT10
Battery in boot relocation
RB20 gearbox
Unknown clutch
Unknown LSD
JIC coilovers-front(leaking)
Tien coilovers-rear
JIC castor rods
Cusco strut brace
Rays Volk 17x7.5 +32 front
17x8.5 +38 rear
Federals 595s
Monkey house URAS kit
Custom paint called blurple (black/purple)
Bucket seats
KKR deep dish steering wheel
Nismo gear knob
Apexi auto timer
HDi-SBC-D-Evolution
Stuff to be fitted:
Oil catch can
Water and oil temp gauges
Battery clamp
Fire extingusher
Wish list:
Tein super streets w/tops
or ISC N1 coilovers
Rear camber arms
HID 6000k
Cage
I bought it out of the spare of the moment last year after wanting one for about 4 years and had to have a sunroof, but it leaks :P
Been adding a few bits here and there, i had the head rebuilt when i blew a radiator hose at mach 2.1 on the highway and got the new radiator (old one was cracked) and put the GT30 on.
Trying atm to legally get it back on the street but it is my drift car and gets trailered to willowbank drifts. Needs another tune with the new laggy turbo and adjustment made to the cams to reduce it (i was running it of the actuator which was even more laggy, ebc made a big difference) but it makes around 250kws atw on 16psi
Cheers
https://www.sau.com.au/forums/topic/270172-the-devils-cef/
  • Replies 57
Posted Images
  • 1 month later...
  • 1 month later...
UPDATE:
Saved up some cash while away with work then bought some goodies...
Buddy Clubs P1 f17x8 r17x9
Volks will become my drift rims...
Silk Road Coilovers ordered
Got BIGGER calipers for the front and some DIN gauges as well.
Thinking of coloured rims, possibly powder coating in some ridiculous colour. Rims will get 8mm spaces on them so they will hug the guards, bolted on with rays engineering lug nuts anodized red...
https://www.sau.com.au/forums/topic/270172-the-devils-cef/#findComment-4743449
***Update***
Z32/R33 brakes are on with GTS slotted rotors and EBC Green Stuff pads. Cleaned them all up, took for ever with copper wheel on my drill, but came up sweet after spraying them in Hi Temp Paint...
Before and After cleaning and paint stirping
After a brake bleed, well actually several, there still seems like there is air in the system, not sure if its my proceedure bleeding it or my mater cylinder cant keep up with having bigger brakes. They came of a mates 180sx and worked fine plus he had no spongy brake pedal. They do pull up a hell of a lot better. Gonna look in to it more...
Also bled the clutch, had heaps of gunk in it, now clutch engagment is right at the end of the pedal travel(top). This is now 1cm high then what it used to be, so gotta get used to it...
Buddy Club wheels on the car, photo taken from my phone, but I added a red pin strip to give it that RAYS Volk Racing CE28N's look. Old volks are now my drift rims but need to buy some 25mm bolt on spacer as it scrubs the chassis rail even with 8mm spacers....
This is how it sits atm, collecting dust in my car port, hasnt had a wash in 6 weeks now, been real lazy on it, so hard to get motivated when its been defected and no street driving argh...
Gauges are fitted and wired up, very important oil pres, oil temp and water temp. Cleened up some wiring under the dash, found heaps of scotch locks, hate thoughs damn things and removed some of the old sound system. Noticed after a few drives especially at night the oil temp got below 40C thanks to my oil cooler but it is damn too cold and kept a high oil pressure, but all drives were with no front bar, so might see if it makes any difference with it on and if it doesnt make any sort of change, I will probably make a cover for it so it so it doesnt stay so cold...
Still waiting on the Silkroad Coilovers, in the mail atm. Will have a write up on them before, going in and after install...
After coilovers are in, gonna get an engineering cert, then back on the streets and drive it to QR...
Will post new gauges and more wheel pics this w/e....
Cheers, Matt
https://www.sau.com.au/forums/topic/270172-the-devils-cef/#findComment-4779828
Were the brakes a direct fit? or did you need to change hubs, nuckles etc?
As for painting the rotors, wont that kind of just get stripped away pretty quickly .... ??
GTS Rotors ??
Looks mint man.
How much were your Coilies, and whats the specs?
I'm trying to find a street friendly set for mine, Tein dont make them, and I've been told to keep clear of H2s, and not to use S13's.
https://www.sau.com.au/forums/topic/270172-the-devils-cef/#findComment-4780682
GTS Rotors ??
Looks mint man.
Brakes were a direct fit, no changing hubs, or nuckles. Only thing I did extra was add a washer to space out the banjo fitting in the brake line to the caliper. If your going to do this I recommend removing the dust shield behind the rotor.
I only want to paint the centre part and outside of the rotor, after a few applications of the brakes the part were the pad is touching will be stripped away. I sprayed them back because im fitting bolt on spacers and black on black is hard to spot for the inspecting officer to see if you know what I mean...
GTS rotors, the are from a R32/R33 GTS Skyline non-turbo which uses 4 stud instead of 5, but you can use any rotor that will fit.
Coilovers were cheap, not bad cheap but good cheap. I source them from J-land and got them shipped over to Aus for a good price.
When buying coilovers you get what you pay for, if your gonna buy something cheap/average quality dont expect to much. S13 coilovers are fine, just as long as you get heavier springs to suit the RB20 motor. I think I went for 8kg front and 6kg in the rear, but it all depends on what you want and what you are gonna use it for. ie street or drift...
https://www.sau.com.au/forums/topic/270172-the-devils-cef/#findComment-4781343
GTS Rotors ??
Looks mint man.
https://www.sau.com.au/forums/topic/270172-the-devils-cef/#findComment-4781345
Hey dude are you still having your brake troubles? cause in the photo of the caliper close up you can see the bleed nipple for the caliper is on the bottom of the caliper, this should be on the top so when you bleed it all the air comes to the top. so swap your calipers side to side and this should fix the spongy pedal
https://www.sau.com.au/forums/topic/270172-the-devils-cef/#findComment-4786329
Haha yea, a mate noticed that just after that photo was taken, it was only a trail fit at that stage. The brakes werent on till I got the brake dust covers off first which involved getting the hubs off that were rattle gunned on so tight I broke 2 breaker bars.
Will do another brake bleed when I get my coilovers.
Good pick up, cheers.
https://www.sau.com.au/forums/topic/270172-the-devils-cef/#findComment-4788322
  • 3 weeks later...
i ended up changing my master / booster with r33 items to fix the spongy brakes , requires a tiny bit of modification , but nothing a decent backyard mech can't do :D
I might look into it if I find problems on the track. What did you have to do to make it fit? Ultimately I would like to get a Non Turbo 300ZX brake master/booster as they have more rear brake bias. A mate fitted one from a Nissan Partol and said it worked well but he had a bias adjuster in his 180SX...
Also, fitted the bolt on spacers which I'll be using for the track. Looks phat and no more chassis rail rub, yay...
Cheers...
https://www.sau.com.au/forums/topic/270172-the-devils-cef/#findComment-4842642
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
