  • Replies 57
Posted Images
  • 4 weeks later...
...you're not welcome here anymore dude :3some:
Nah that looks alright hey...but put a spoiler back on...they look weird without anything on...even the stock one will do.
Street legal with no drama's ?
Ha ha, I still have the Ceffy till its sold.
The boot used to have a spoiler but the holes were only taped up so I got a carbon fibre lid for it and it make it look tough from the back....
Engine, gearbox, turbo and intercooler are engineered, but with a 3.5 straight through exhaust from the turbo back is way to loud so I'm looking at one of though varex xforce mufflers for it.
As for drama's, clutch failed after I bought it and drove from Brisbane to Sydney and the power steering pump decided to fail on me. But its all fixed now.
But other than that it make 401 hp on roughly 1.1 bar of boost and is a handful even with semi slick on the back.
Whats been happening with your Cefiro? How'd your HSD's go?
Going good man, got them but havent installed them yet, pending 5 stud conversion, brake and wheel fitment. Everything else is starting to move again, which is good. :3some:
Not sure on where and which brand to get my studs from.
the CF looks aight hey, CF roof and bonnet gets my vote.
What kind of 1/4 times does it pull, do you know yet?
Must be decent considering its weight and a 3.0 twin turbo engine pushing 400 out it's ass...must also be a bitch to drive in the wet too, haha.
Going good man, got them but havent installed them yet, pending 5 stud conversion, brake and wheel fitment. Everything else is starting to move again, which is good. :)
The car has run a 12.4 @ 122mph, with a lazy launch then wheel spin into third by the previous owner. I hope to get a flat 12 with launch control tuned into the computer, plus get some 1000cc injector and better coils as the are stock ATM and really holding back more power. Off boost its drives OK, in the wet I don't boost it, that's just asking for crash LOL...
  • 1 month later...
  • 4 months later...
Hey dude mean looking ceff, Its darrens old one isn't it? from autoshop
ALso did you get the S15 from peter? Hes the only dude i know crazy enough to do the conversion!
I bought it from a guy who imported it thru autoshop, dont know if it was ever his. S15 conversion was done by a guy named troy...
U mean brakes? and z32 calipers are a straight bolt on, just got some slotted rotor to suit.
oh yeah haha brakes... nah i mean with the bigger calipers having a slow/softened effect on the pedal, did you have to upgrade the master?
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
