  • Replies 103
Yes, I have been budgeting for this build for 2 years working 6 days a week.
I have been sacrificing all unnecessary luxuries for this - No beer!, no going out, no movies etc. I WISH I had too much money.
In fact, I am still working 6 days a week, preparing for Racepace's BILL..... :D
I will pics of brakes tonight.
AP Racing Formula Big Brake kit for R34 GTR
355mm two piece rotor with patented AP Racing Strap Drive:
330mm rear one piece cast rotor:
Front 6 pot caliper:
Rear 4 pot caliper:
Size comparison between Fr and Rr calipers:
Accessories: Fr brake tubing & Rr Goodridge braided brake hose; Fr mounting bracket; Ferodo DSC2500 brake pads; DOT 5.1 brake fluid
More detailed photos of other parts to come!
Matt: price for AP 330mm rotors and where from and how thick please?
Thinking about adapting those to my 315mm Alcons.
Cheers!
lol as an add on, price for full brake kit? hehe.. :action-smiley-069: lookin for brakes :blink:
Edited by ujin
EDIT: just noticed youre using racepace. ill leave this for anyone else chasing a workshop!
aweomse build dude, good luck with it!!!!
i suggest contacting duane at hi-torque in doveton. power rd off princes hwy. he has built quite a few 2.8L motors and specialises in gtrs
ph: 03 9792 9984
cant recommend him enough! no bullshit, honest answers and expectations, awesome tuner! has a 4wd booth etc
Edited by Houghy
Can someone recommend a workshop who can carry out the engine build and tuning, besides RACEPACE.
Racepace has taken on the job
:) I lol'd
Kit costs $9500-9800 depending on vendor.
:rant: Fark man. Your brakes are worth more than most cars on the road.
Yes, it is very astute of you to notice that I asked for recommendation for a workshop for the build besides Racepace and then to announce a week or so later that Racepace has taken on the job. I have a very good explanation for this strange behavior. However, I am not at liberty to disclose this until the time is appropriate.
I will post pictures of V Cam unwrapping over weekend perhaps.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
