Make: GTR
Model: R32 1989
Milage: 105 000
Transmission:5 speed
Colour: Gun Metal
Complied? Yes
RWC supplied?
Currently registered? Yes
Price: 25,000 neg
Contact: 0434392282 Ryan,
Modifications:
GT35r twin bb turbo bought new from horsepowerinabox.com ( with turbo bag)
Stainless exhaust manifold
HKS 50mm external wastegate
Apexi power fc de-jetro (map sensor not afm) with hand controller
Poncams (so i have been told)
Adjustable HKS cam gears with new blue timing belt, gears have not been adjusted.
650cc injectors
Ceramic coated inlet manifold
4 inch cooler
Front mounted ARC oil cooler ( fits where grill goes)
Fully adjustable pillow top ball joint suspension
Adjustable upper rear camber arms
Stainless Exhaust cat back
18 inch 5 spoke white Enkei rims (Brand new 235/40r18 yokohama v103s)
800hp single plate clutch.
340kph dash
Rear hicas has been removed with a lock bar in place.
Brand new front cv joints
All new suspension bushs in front end.
Coil over suspension
Front mount arc oil cooler
Oil filter relocated.
Fully rebuilt nismo rear diff
Drilled and vented rotors with near new pads
Two intank walbro fuel pumps
Crbon fiber bonnet
I was told the engine had been built with forged pistons and acl bearings and has had some head work, but i have not had the motor opened so im not for sure about this. (previous owner) im the third owner in australia. The car is in quite good condition for its age, has a few scratches on the front and rear bar. I cannot supply with all reciepts for work done and completed to car as alot havent been passed on from owner to owner but can provide a few.
Please contact me via PM or mobile(work hours only)
Now with pics, more specific ones can be taken at requets.....
<a href="http://s7.photobucket.com/albums/y299/whii...=Picture007.jpg" target="_blank"><img src="http://i7.photobucket.com/albums/y299/whiiiz/Picture007.jpg" border="0" alt="Photobucket"></a>
<a href="http://s7.photobucket.com/albums/y299/whii...icture014-1.jpg" target="_blank"><img src="http://i7.photobucket.com/albums/y299/whii...icture014-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://s7.photobucket.com/albums/y299/whii...=Picture016.jpg" target="_blank"><img src="http://i7.photobucket.com/albums/y299/whiiiz/Picture016.jpg" border="0" alt="Photobucket"></a>
 Share
    • Looks like a scam. It has all the telltale signs: - The "business" doesn't have a physical address or really any kind information listed - It's using a generic online store website template - The prices are ridiculously reduced. To good to be true cheap - Everything is in stock and can be ordered in any possible combination   I've seen a few of these for other products as well. Things like sunglasses for example. I'd say stay away from it! And maybe reach out to the real theskylineshed and let them know this exists. I doubt there is much they can do about it, but still.   I don't know if they would actually take your money if you ordered something. Or whether it is just for collecting credit card details to scam otherwise. I'm not game enough to try it.
    • Hi guys has anyone ever bought from this website theskylineshed.shop?? Not theskylineshed.com as I’m aware there is 2 similar but different sites.     has anyone had any issues with theskylineshed.shop???
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
