Hi can some one help. I have a 1990 r32 gtr i have rebuilt engine with argo forgies argo billet rods and acl race bearings. Engine has been goin sweet untill last nite. standard but but had it checked before re assembly
Oil gauge has never read right been told is a common problem
Question do 32 gtr have an oil pressure light if yes mine must not be working?
Boosted to 16psi racing some1 end of race car making big knocking noise have had in diagnosed and yes it has done a big end.
Have not tested oil pressure on mechanical gauge.
So what would be th most likely cause of oil pressure loss in these cars.
What is the soloution to this problem?
What is easiest method of removing the sump. A dropping cross memeber or engine removal.
one more question if they do have oil pressure light does it come on when ignition is frist turned on.
the oil light should come on when you turn the ignition on before starting.
and the gtrs are common to have oil pressure problems. i blew my oil pump ( common to go ) and i had to remove the sump to do so.
and to remove the sump you have to take out the gearbox as bolts are inside which are hard to get. i took out motor and box.
and 16 psi is alot i heard to be running on standard turbos.
This is all true mate . Often the oil pressure sender will fail and read low pressure (very common as said and oil light is on guage unless bulb is shot) You still getting pressure afterward? I hate hearing this with fellow rb owners but its nearly a fact of life... if you rebuild it... replace the oil pump. and /or crank collar with early r32 engines. Oil light should come up during ignition start up. Easiest way to remove oil pump is remove engine...remove sump. You've probly heard it before but oil pressure is utmost important and i wouldn't touch a car fo any sort of maintenance if it was reading an abnormal oil pressure. I wouldn't even drive a car if i thought something was suss! All in all from what you've indicated as the cause a spun bearing requires a bottom end rebuild anyway. sorry to hear.
bad luck mate, that sux :( hope u can get it fixed without too many hassles..
can I just ask, as Im looking at possibilities of forging my own engine... what makes a recently rebuilt motor with stronger internals sh*t itself and not even reach 10,000kms? I thought they would last after being forgedt?
gl with it mate.
There's probably a lot of things that will make it go before you hit 10000k's.
Including, but not limited to:
Oil problems
bad assembly
shit getting into the engine while your rebuilding it (aka, metal flakes etc)
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
