Hey just a quick question in regards to joke seals, well this is my 2nd one ive gone through in a few months gearbox is in good condition an using redline lightweight shockproof oil.Is this a regular issue with these boxes? could it be a pressure build up running high boost,ive got an inline filter for gbox oil so could this be a problem?thanks
https://www.sau.com.au/forums/topic/270244-rb20-5sp/
I'm curious to know how the in-line filter works given there's no pump in these gb's. Depending on how this works it might be a factor. Engine boost should not pressurise the gearbox (in a stock gearbox setup)
You may have a blocked gearbox vent, which is roughly in the middle of the extension housing, at the top.
https://www.sau.com.au/forums/topic/270244-rb20-5sp/#findComment-4597772
Yes i was thinking the same with the filter there, i will remove it an check the vent. thanks man
https://www.sau.com.au/forums/topic/270244-rb20-5sp/#findComment-4597953
