93' Model R32 Gtr
this GTR is on here to be sold.
as per the rules i must put up a asking price so here it is $25k
Genuine offers only!
car needs to go, owner has other commitments
1993 model r32 gtr, original grey colour in immaculate condition. No scratches or dents. rarely driven. allways serviced with the best oil's and coolant. 150,000 klms and reliable!
P1buddy Club wheels 17x9.5's
DBA 4000 series slotted rotors with green stuff pads
Bilstein coilovers
CUSCO castor adjustables
CUSCO camver adjustables rear
Midori upper adjustable camber arms
APEXI Power FC with hand controller
HKS type-S engine oil cooler
HKS Fuel rail
HKS 900cc injectors
HKS primary exhaust pipes
HKS Cam Gears an Gates Racing belt
Tomei cams
n1 turbo's
Sard Fuel Reg
braided hoses throughout!
Alloy surge tank
Walbro Fuel pump
External Bosch 700hp Fuel pump
Splitfire coils
Brand new crank angle sensor
Brand new ignition module
Brand new ignitor harness
Brand new Z32 airflow meters
Brand new APEXI Super suction kit with Z32 plugs
Custom advan airbox
New N1 water pump,timing belt idler, an adjustment pulley with new half moon cam seals
PWR Radiator
Nismo strut tower Brace-Front
Jun metal Intake gaskets
twin HKS Sequential BOV's (hidden in gaurds)
HKS wastegate
HKS FMIC with HKS hard piping 600x300 by 110
TRUST Clear timing belt cover
5 Puk Jim Berry Clutch(heavy duty single plate)
New nismo slave Cylinder an Pivot ball
Greddy Exhaust temp gauge with memory recall
Greddy Boost gauge with memory recall
Greddy A-Pillar Dual pod gauge holder
Greddy Profec-B eletronic boost control
Greddy turbo timer
latest cobalt series Autometer monster tacho
Blue led dash lights
Sparco Racing - driver side
Sparco steering wheel
i might of left some things out but have reciepts for $$$$$
Car has made 320awkw on 1.1 bar can make more power but this is perfect for street.
it has ran a time of 11.6 at WSID on premium unleaded.
was recently defected by the rta and epa. rta only defect was the ride hight(easy with adjustables :D ) and the epa was passed with a niose test and emmission test. passed successfully so all parts are included with the car. incase it happens again. its as easy as bolting the parts on and offf...
Located in sydney.
I WILL BE PUTTING THIS CAR FOR SALE ON OTHER SITE IN 1 WEEK
so you guys have the first preference now, dont waste it.
can u post a pic with the black wheels???
here are the latest pics ,
also this car has ran a 11.6 on a 280kw tune more than 2 years ago. It now has 320kw and i am confident that it can crack into the 10's with the right driver!!!. I wish i had the time and money to do it but unfortunately i dont...
I wanted to put this car up for offers only and no asking price but i tried that before and was deleted by the moderators... so guys this is no joke when i say this car NEEDS TO BE SOLD...
Yes, I'm interested, can you please post some pictures of the inside so i can see interior and gauges. Am cash buyer, no trades, I am searching over Australia in next 2 weeks to find the right one.
the interior is fairly standard besides the driver SPARCO seat... no tares or stains
its clean, seats are allways covered with seat covers... also all the dash lights are blue... or is that original?
not too familiar with these cars mate.
price in nego
pictures are poor quality sorry
check out mine to mate if ya searching around. its on carsales.com rego number is gtr089 just type that in and have a look. im in strathalbyn, SA. gunmetal grey GTR
 Share
    • Ah damn. I might grab one myself because mine works most of the time lol
    • Yes, I mentioned it in my first that I did everything that is mentioned online (Redo dry solders, clean connector between PCB's, etc.) and unfortunately it didn't solve it.  It crapped out again earlier today, so I replaced it. I'll keep the old one around to repair it at some point.
    • I've looked at some oval stuff but still deciding what material to use for the back half to the muffler.   Yeah I do all my own stuff with ecu setup and have it sorted before generally paying someone (my old work) to do base runs and a few power runs then I'll do anything else myself at track or after review data. It's hard to find  a dyno owner these days that will hire out to random.
    • Injectors are told by the ECU to open for certain amounts of time. If the injector flows more fuel, but the ECU doesn't know this, and is told to open for the same amount of time as the stock, smaller injector, then the larger injector will flow too much fuel/more fuel than the engine/ecu is expecting. You absolutely need an ECU to control injectors. You don't need a tune for a fuel pump (because your fuel pressure should remain the same assuming the regulator works). You don't need a tune for an exhaust (the parameters for fuel and air going into the motor have not changed much) You don't need a tune for an Intercooler (the parameters for fuel and air going into the motor have not changed much, it's just the air is cooler) Yes, forum regulars, I know that you really should get a tune for an Exhaust, and Intercooler. These *will* affect the tune, but the stock tune does have some leniency to it with stock AFM and Injectors. Intercooler and Exhaust will fit within this wiggle room. So will running a boost tee to about 10psi, which is a very old way of increasing boost which is not worth doing in 2024. The ECU is vital. It runs the whole show. Most people change injectors and ECU at the same time for this reason. Some people load base maps on some ECU's that have ballpark figures for injector sizing. Sometimes injector manufacturers are really great and tell you what parameters to input into your ECU, which is something you can do with your new shiny ECU. For a beginner, this may enable you to drive to the tuner to have an expert do the rest. Otherwise, you're installing injectors and ECU at home, and paying for a tow to a dyno. Or, you take the car to a workshop (be happy to travel across Melb for the right shop) and someone who knows RB will be able to source/provide/install injectors and tune the car at the same time if they have a dyno or access to a dyno. The reason so many people DIY things here is because finding said workshop is hard, expensive, potentially getting things wrong with miscommunication/other.
    • @robbo_rb180 do you tune your cars yourself or do you send them to someone? If you do it yourself, do you hire a dyno, or tune it after logging it at the track? Meaning like touch ups when you tweak or modify something a bit
