  • Replies 218
mate could you pm me details of this product for the r32 gtr (track version) or anything. please include hor much negative camber would i be able to achieve. i pm'ed you but no reply. i m really interested!
yes agreed i pm,d a while back and no reply also.
sorry guys for some reason i can only do one pm every ten minutes( and work doesnt like me doing it ... funny that)
im over at uniques today and will find out a confirmed time frame
if you need any pressing info.. give me a bell
ill get johnny to come on here and confirm when they will be ready for delivery!
i have i think 7 confirmed deposits
ill update the list this weekend so every one knowes that they are on the list
pete
0448468884
Hi gang, sorry for not keeping an eye on this, and yes Pete gave me a shove. Anyway we are getting two version made, one for road- track cars and another for race cars, from memory option for 10mm longer and 20mm shorter, and standard length to 30 mm shorter for race cars. Also there has been a slight improvement and change in fixing the main body, now using a cotter pin, which is getting made. No extra cost. They are delayed, yes, and still a few weeks away. I will update with pics and or info.
If you get road - track version you can always cut it shorter if needing more neg camber, if turns into a race car only. I have the shorter prototype on my Zed race car, and can go up to 5 degree neg. I have used with no issues for about 3 years, suspension works better as does not bind, steering is lighter and has more feel, and it does not wear out.
Re camber, the road- track version should range from about .5 degree neg to 3 deg max, and race from about 1.5 deg neg to 4.5 deg neg. These are estimates as depends on height of the car, and if has stock length lower control arm and inner pivot point is stock, or moved outwards, as some race cars do this mod, in which case you can probably go up to 6 degrees neg.
SOunds good
Thanks for the update.
I am keen on getting at least one race version, possibly 2
I will keep an eye on this thred as much as i can but It would be awsome to recieve a pm for when we are closer to a point of ordering for these, for which i will happily deposit money straight in
Cheers
Tim,
sorry for the noob question, do these use bearings?
What are the lifespan of these? Need any maintenance or set it and forget it?
Is the group buy price still available? Interested in a road pair
Thanks
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
