  • Replies 218
mate could you pm me details of this product for the r32 gtr (track version) or anything. please include hor much negative camber would i be able to achieve. i pm'ed you but no reply. i m really interested!
yes agreed i pm,d a while back and no reply also.
sorry guys for some reason i can only do one pm every ten minutes( and work doesnt like me doing it ... funny that)
im over at uniques today and will find out a confirmed time frame
if you need any pressing info.. give me a bell
ill get johnny to come on here and confirm when they will be ready for delivery!
i have i think 7 confirmed deposits
ill update the list this weekend so every one knowes that they are on the list
pete
0448468884
Hi gang, sorry for not keeping an eye on this, and yes Pete gave me a shove. Anyway we are getting two version made, one for road- track cars and another for race cars, from memory option for 10mm longer and 20mm shorter, and standard length to 30 mm shorter for race cars. Also there has been a slight improvement and change in fixing the main body, now using a cotter pin, which is getting made. No extra cost. They are delayed, yes, and still a few weeks away. I will update with pics and or info.
If you get road - track version you can always cut it shorter if needing more neg camber, if turns into a race car only. I have the shorter prototype on my Zed race car, and can go up to 5 degree neg. I have used with no issues for about 3 years, suspension works better as does not bind, steering is lighter and has more feel, and it does not wear out.
Re camber, the road- track version should range from about .5 degree neg to 3 deg max, and race from about 1.5 deg neg to 4.5 deg neg. These are estimates as depends on height of the car, and if has stock length lower control arm and inner pivot point is stock, or moved outwards, as some race cars do this mod, in which case you can probably go up to 6 degrees neg.
SOunds good
Thanks for the update.
I am keen on getting at least one race version, possibly 2
I will keep an eye on this thred as much as i can but It would be awsome to recieve a pm for when we are closer to a point of ordering for these, for which i will happily deposit money straight in
Cheers
Tim,
sorry for the noob question, do these use bearings?
What are the lifespan of these? Need any maintenance or set it and forget it?
Is the group buy price still available? Interested in a road pair
Thanks
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
