  • 3 weeks later...
  • Replies 218
Would you ship to the UK? As my R32 GTR is wearing out the tyres on the outer edge which i believe is due to the toe or camber and im uncertain if the standard setup is adjustable? Therefore im hoping this can correct the problem?
  • 6 months later...
Righto ladies
Anyway that last group buy actually cost the supplier money so I have asked again to revise the price to make it worth his while
The last one most people were happy, some people requested additional camber (eg ability to make them shorter)
I have requested if we get 10 people that they make them slightly thicker (stronger) and for additional camber adjustment.
Please not there is only so much you can do so if you want the ultimate camber solution give me a bell (involves mods to your sub frame)
We need ten orders, price is $550
I won’t f**k everyone around buy saying they will be ready in a week. So I am going to say once we have ten orders it will be three months
If it turns out quicker then so be it, I may also put up new group buy thread
Basically let’s say 250 up front then 320 including delivery when they are ready
bank details peter carruthers
bsb 112-879
acc 428 965 807
people who want in below (only 9 to go before we order)
1 fatz
2
3
4
5
6
7
8
9
10
Potential
godzilla32
josh type x
endless
sbr
I will most likely be cancelling my interest. I am getting some R33 LCA's and already have adjustable bushes, so I'm hoping that will give me sufficient camber.
1 fatz
2 sbr
3 willis
4 sav man
5 endless
6
7
8
9
10
still need 5 people
to help generate additional interest perhaps we should make a new thread like you suggested earlier. or just change the topic name so that people know it's round 2 ;)
-4 should be achievable with this batch of arms? :)
Edited by Willis
  • 4 weeks later...
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
