  • Replies 218
cos was thinkn of running more (or is it less...i mean more negative) camber in so isnt this the part i need? just something like -3 top :S
Na man 33's have a diffrent setup all together.
If you already have a cusco style adjustable uper arm you will need an Ikeya adjustable lower arm. But I think the cusco style upper arm will allow plenty of adjustment.
Go to Just jap for all of the above
very interested in a track version and quite posably 2 pairs .
i will be happy to deposit money once i know the adjustment availiable.
feel free to pm me with the adj details and bank details at the same time
cheers
Tim,
lol, everyone has the same idea. every single bloody set of arms or bushes for 32 does not give anywhere near enough neg camber. the only way up till now was cut and shut factory arms to get you that nasty 5 degrees neg you want. but if johnny listens to me (and he will or I will ridicule him for life) these will be the best arms on the market. :) cure the binding/bush wear issues and the lack of adjustment issues in one hit.
righto status is that jonny is getting back to me with a manufacture time once i have that ill make a last call for deposits then ill hnd over your deposits to johnny and you will pay him the reminder when they are ready for pick up
pete
0448468884
Still haven't received a reply to my pm's mate....i would like to get a set of these,
expressed interest on the 26th of June.... i didn't get any bank details to make a deposit?
i don't want to miss out on a set of these great items
Z
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
