  • Replies 218
mate could you pm me details of this product for the r32 gtr (track version) or anything. please include hor much negative camber would i be able to achieve. i pm'ed you but no reply. i m really interested!
yes agreed i pm,d a while back and no reply also.
sorry guys for some reason i can only do one pm every ten minutes( and work doesnt like me doing it ... funny that)
im over at uniques today and will find out a confirmed time frame
if you need any pressing info.. give me a bell
ill get johnny to come on here and confirm when they will be ready for delivery!
i have i think 7 confirmed deposits
ill update the list this weekend so every one knowes that they are on the list
pete
0448468884
Hi gang, sorry for not keeping an eye on this, and yes Pete gave me a shove. Anyway we are getting two version made, one for road- track cars and another for race cars, from memory option for 10mm longer and 20mm shorter, and standard length to 30 mm shorter for race cars. Also there has been a slight improvement and change in fixing the main body, now using a cotter pin, which is getting made. No extra cost. They are delayed, yes, and still a few weeks away. I will update with pics and or info.
If you get road - track version you can always cut it shorter if needing more neg camber, if turns into a race car only. I have the shorter prototype on my Zed race car, and can go up to 5 degree neg. I have used with no issues for about 3 years, suspension works better as does not bind, steering is lighter and has more feel, and it does not wear out.
Re camber, the road- track version should range from about .5 degree neg to 3 deg max, and race from about 1.5 deg neg to 4.5 deg neg. These are estimates as depends on height of the car, and if has stock length lower control arm and inner pivot point is stock, or moved outwards, as some race cars do this mod, in which case you can probably go up to 6 degrees neg.
SOunds good
Thanks for the update.
I am keen on getting at least one race version, possibly 2
I will keep an eye on this thred as much as i can but It would be awsome to recieve a pm for when we are closer to a point of ordering for these, for which i will happily deposit money straight in
Cheers
Tim,
sorry for the noob question, do these use bearings?
What are the lifespan of these? Need any maintenance or set it and forget it?
Is the group buy price still available? Interested in a road pair
Thanks
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
