  • Replies 218
Fatz / Rob260,
When do we need to pay the final amounts? Do we pay these to UAS or through you Fatz (more cas money for ya :) )
Hi mate, not 100% sure how fatz is doing things BUT the way I run it on aus300 is money due when the parts are ready to send. The balances (plus shipping where applicable) get paid direct to UAS.
You will have to clear that up with Fatz though if you are part of his group buy.
When are the second group buy orders commencing roughly.
Won't start taking orders on these until the first batch is out the door. It's great that so many of you guys are keen but I think taking orders for a second round with the first still overdue would be asking for trouble.
So what's the holdup? As I mentioned before the cotter pin is tapered, so you have to drill the tapered hole before you make the pin. At the moment the guys are waiting for the tooling to turn up so that they can drill and make the pins. The remaining labour is minimal, as in less than a day to finish the set. As soon as the tool turns up we are all good to assemble.
So how far off are we now?
Got another set up for grabs from round 1. Guy has no job and money is tight... $197.50 to whoever gets in first.
Re timeframe there is minimal work left, just a case of when the tooling turns up.
Hi mate just after those camber arms...
so 197.50?
i read there were two versions somewhere, track and street, is this the case and if so which one is this set?
so does 197.5 cover the whole lot?
PM ASAP
Fatz: PM sent last week.. still after these, paid deposit 6+ months ago, want to know how I make final payment and receive the arms.. Talk to me bitch.
well i tell you what
johnny just called and he is picking the suckers up as i type
he has requested teh last payment and shipping and he will have them shipped within the week
the list of people who have paid a deposit are:
zurlox
lotus folding
ezzo
salad
pedator
adam macbeth
chris hall?
razor 32
john camber
my gtr32
yea baby were on!
two option
call me
0448468884
you can pay me
or the prefered option is call unique autosports 96209000 and they will tell you the shipping and give you bank details
pete
Pete, I'm going to get these sent to my work. If they're being posted I can only use a PO box. If couriered then only the physical address. Which shall I quote? Also, can you confirm the total asking price and the deposit amounts? I won't go into why I don't know, I just don't......Finally please can you confirm I'm getting a 'race' set.
Thanks.
EDIT....is it $395 / 2 + $20
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
