  • Replies 218
update that i got from UAS
Leaving on Monday by Toll Ipec will be:
Showza – 1159740000612
Jon Richards – 1159740000613
Adam Mcbeath – 1159740000614
Sam Petts - 1159740000615
nick i need an address as the courier will not deliver to a po box apparetly
Ok so after that last lot - the GB is done?
If so, all good. You are free to start another thread Pete.
Can't have anymore "never ending" group buys, its becoming impossible for people to work out what is going on with 5+ pages.
Cheers
ASh
What about the others? Like Gordon C**** ? Only prob is they arrive between xmas and New Years, our office will be closed.
I can wait till Jan, that doesn't matter, but coming up to Xmas is a bad delivery time.
Yep, unless these get away today they will go into the Xmas shutdown wasteland. Even today is stretching it but at least it's a courier and not the post. Can we have some confirmation of exactly when they left?
Got mine today!!, they look sweet, although both have a painted "R" on them.. is that correct? and what does that mean? if it was a R and a L i would have thought left and right, but both have R painted on them. wierd.
Maybe the R is for the race style ones?
Got mine today about 5 mins before I locked the joint up until the new year. I ordered race but no R on them. Perhaps you can clarify how else I can tell if I got what I've ordered. I ordered race.
everyone got race exceptone person
their is no left or right you just twist the car side of the arm 180 derees dpending on what side its on
er, so am I the one, or did I get race? Merry Xmas all.
Cheers
ASh
Can you gimme an answer you big hunk of a man you? :)
ash yea this group buy is now dead
the arms are universal
any dramas call me and ill sort it out with johnny
also there will be another group buy but they will cost more as they are manufactured in australia
eg not chep china shit
cheers
pete
0448468884
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
