My New Setup Feel Slower Than My Old Setup!
not really buying the laggy turbo's are slower but seem faster argument. (within reason)
turbz 25, i think you should just take it to a different tuner. Every tuner is different.
not saying your current tuner is a bunny, but if a different tuner comes up with simular results, then you would think its maybe something in your setup.
even just get a power run on another dyno and maybe get the AFR's checked again.
its a shame to hear you pumped quite a lot of money into it and your still not happy. good luck with it!
The GT3582 combined with a 0.82 housing on a RB30/25 should provide a great linear type of result – ie keeps on climbing with rpm. And looking at the overlays it does so, while the 2835 tends to flatten off across 120-150km/h with a bit of a kick at the end. I’d be chasing that smooth progressive delivery any day.
If you want a searing mid-range rush, slip a 0.63 A/R housing onto that GT35. It’ll be anything but “boring”, but just don’t expect it to be easy to drive and achieve traction. Power-down is important if you want to go fast, as opposed to feel fast.
Either way, looks like you’ve got a pretty good setup overall. The numbers are there, with room for more. I didn't notice any complaint about whether it goes fast, just the feel. Before you do anything, take it for a good run at the track (or strip), and let us know what you think then.
ive got exactly the same setup and although i dont think its boring, it would probably feel a little slower than some other cars that have more of a hit.
this setup is very easy and nice to drive and boost comes on quite progressively. i dont think there are any issues whatsoever, rather you would be use to feeling a kick, and now the kicks gone.
if you have raced the old setup at a drag strip or done 0-100 times, try the new setup. im 100% positive you will find its quicker.
when i talk to some people about my setup, i say that it spools similar to a stock turbo, just it keeps going and going
cheers
Hey boys thanks for all the comments.
I'm gonna save up for a ViPEC V44 ECU (get rid of the AFM and PFC, already maxed out at 312 rwkw), get me some Nismo 740cc injectors and a bosch 044 fuel pump.
I'll probably take it up to newcastle so Guilt Toy can work his magic on my car.
I know the car has more power than my previous setup, I can tell by the amount of wheel spin it achieves in second gear, but, it feels slower......
I guess the only way to tell is to print of a torque curve and compare the setups.
Also, I am a little worried about getting the V44, there is no knock sensor... WHat happens if you get a bad batch of fuel? It'll be pinging off it's tits and you wont even know...... Scary.... Maybe I should stick with the Power FC?
Anyways, thanks for the comments fellas.
I have the same problem with the new turbo setup i put on. Personally the car is actually alot faster and have proved that on the 1/4 mile but it feels very slow compared to how it used to. Does not feel as aggressive and punchy. But in saying that a smoother tune is better even if it feels slower. Take it to the track i bet its not and it just the way the power comes on that makes it feel slower.
why you would make more changes - i got no idea, you should sort out what is wrong, or at least verify if something is wrong
The reason I am upgrading the ECU is because the AFM maxed out. So, rather than investing time and money trying to find a right AFM that won't max out before 350 rwkw, I may as well get a Vipec v44.
Although, I'd love to retain the PFC, it's a great computer, and the hand held controller makes it a bliss in terms of monitoring temperature and knock etc...
If anyone has a AFM that has not maxed out before 350 rwkw for sale, please let me know and Ill buy it from you...
I was even thinking of putting the Z32 sensor in a Q45 plastic casing? Might help a little?
I'm curious as to what compression ratio your 25/30 runs .
Also people don't seem to get much joy from those 264 HKS exhaust cams from what I read . How did you end up with a 256 Tomei inlet cam and a HKS 264 exhaust cam ?
You'll probably find that the extended exhaust valve timing means more overlap and that never helps bottom end torque - particularly if the compression ratio is a little low . I'm inclined to think that the matching 256 exhaust cam would make your engine feel more torquey/grunty in most instances .
I agree with some people here about changing your computer , I'd be trying to find out whats causing the lack of performance because if its not computer related changing it won't gain anything in the area your concerned about .
Your calls but I would be chasing killer torque rather than a Kw figure from an engine like that , torque means fast exciting and dramatic if that's your thing . A Kw number is just that - a number based on revs .
Just my 2c , cheers A .
Compression ratio is 9:1. I dunno about the cams, that's what my tunner advised me to get, so that's what I got....
As mentioned before, I'll get a print out of my torque curve and compare it to my old one.....
Thanks for the advice fellas, greatly appreciated..... Gives me some starting points..
I run a link computer which is exactly the same as the Vipec despite whatever people will tell you. Its a great computer and im a big fan, however having also had Power FC's i think they are also very good. I dont think its actually worthwhile changing computers as the additional cost will be horrendous vs purchasing a Q45 Afm. I had a Q45 afm a while back and had trouble selling it for 150 bucks. That will be good until near 400kws.
Btw. My old Mazda Gtx (this is years back) had a much bigger hit than my old S14. Doesnt mean its faster!
Enjoy the new setup. Upgrade the fuel system, and if you do change the computer, buy the Link option as the difference you will save on a Vipec will near on pay for your tune.
Cheers
it's a tough one. 'feel' can be misleading. I have to admit it's a problem I've seen with a few RB30 combos that just didn't feel as 'exciting' to drive. on paper they looked great but just didn't have that same on the edge feel as the Rb25 and RB26s they replaced. It's possible that the old package was much more brutal in it's transition onto boost and that made it feel fast, where as the 30 with the new turbo builds boost earlier and in a more linear way. it is of course possible that the figures aren't exactly right. perhaps have it dyno'd somewhere else just for interests sake. just roll up to a dyno day somewhere, pay the $50 a get another set of graphs for comparisons sake.
 Share
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
