look in the engine bay for a sensor with a vac hose and 3 wire plug.
if thats off its not gonna work. should be drv side
cheers will check in the morn. i think your right cause it didn't work then it did then it didn't so a plug not clipped in all the way sounds like the culprit.
Perhaps.
Mine worked at random times then ceased operation.
Nothing to do with vacuum hoses or clips as all have been changed/cleaned/re-clipped.
It gave 1 final boost reading of 2bar than that was it. lol.
Perhaps.
they don't go up to 2 bar tho. this is the factory item your talking about?
pulled the plug off and sprayed some water dispersant in there and now she's working a treat. must have been the engine wash my mech did when i got it serviced. thanks for the help chris
This is the factory item I am talking about.
It may not have numbers that read up to 2bar.... (sorry for the size, but non of my programs will save the re-sizing atm)
Edited by iamhe77
I can't believe you haven't upgraded your head unit yet iamhe
LOL.
Why though?
I have done my iPod install, run all my music through it (in lossless - I HATE mp3) and it sounds pretty bloody good.
Whilst I know that there are far better out there, the sound from the OE Clarion unit is pretty good and is plenty loud enough for what I listed to (no doof doof).
....plus I would prefer to spend the $1500AUD on "fun" mods instead of the head unit I have in mind :P
What unit have you put in?
  • 6 years later...
Is the boost gauge sensor on all NM35's or do you have to fit it? Where would I find it in the engine bay?
I've got the 3 gauge single DIN (not fitted) and i'm hoping to replace my double din with a single din CD player and the gauges...
Would the loom be there?
Hi Scotty. Ball joints are going great btw...
Not 100% sure what you mean. There wont be a signal for the torque split at both the loom out OR the attessa ECU?
So basically that gauge DIN I bought from you isn't going to work... :huh:
The boost and volts will, but we can't find the torque output at the attessa ecu at this stage, perhaps there are 2 different attessa computers, similar to the dash? You might have more luck.
So there isn't a loom that is common across all cars. The cars that have the 3 gauge will have the plug and the ones that don't obviously don't.
Where is the boost sensor located on the VQ25DET? I thought if you didn't have the gauges, you didn't have the gauge sensor. (hoping to be wrong!)
No, you would be surprised how many differences there are between the body looms. Engine loom is all the same, but the boost sensor comes off the harness on the drivers side of the bay where the headlight wiring goes, it is bolted near the strut tower.
Pretty sure we found the plug for the triple gauges, tucked up under the stereo wiring. I will have to ask the owner I forget. I just remember having issues getting a signal from the Attessa computer.
  • 1 month later...
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
