Hey all,
Have a 1997 R33 GTR, making 239 RWKW with standard computer. Am quite happy with that for the moment and want to keep the factory computer for a while. Unfortunately was hitting the speed limiter half way down the straights at Sandown.
Anyone know how or who can cheaply remove 180km speed limiter in r33 GTR while retaining the factory computer????
Cheers,
Luke.
Hey all,
Cheers,
Luke.
ok have you ever taken a look at the computer? its at the passanger side
ive never tried this myself...since ive never owned an R33....
but apparently there is a wire to the Computer labelled No#53...
cutting this wire....taping it up would disable the speed restrictor....
cutting any of the wires...you could always join it back up...so if i were you, id give that a shot....
why do you need to remove it? because how are you going to test this out?
this would be the "cheapest" way without modding the ecu
make sure you let us know how you go on this.... should this work, ill post it up on the DIY section for future reference. Im pretty sure we need this one in there
Edited by eeiko321
or u could just get a fcd and know thats its gona work 100% without butchering your car
easy and safest way is either
HKS - SLD - Speed limit defender
or
APEXI - RSM
either one will remove the limiter, although I would go the apexi, at least it will give you a few other functions you might find useful on a track.
or
APEXI - RSM
That's safe and nearly $500 retail for the Apexi unit :(
Wire #53 is commonly known as been able to be cut (according to the SkylinesDownUnder I believe), I never tried it personally as if you have an aftermarket ECU you won't need to do that trick :)
cutting 1 wire is not butchering the car, yo can EASILY join it back up :P
EGG f**king zactly!!!!!!!!!!!.................... thankyou...........
or
APEXI - RSM
ermm both you guys i dunno if you read his question...... he asked for the CHEAPEST way possible..........
hes "happy with everything" for now.......so he didnt really ask for jibber and jabber or gidgets and gadjets....
i think this is the most efficient way to suit his needs
do you know if this will work for a gtst is it the same wire .... i have heard of this before and was told that #53 wire is the out put to the ignition module when the computer switchs it to earth the ignition is disabled if this is true its a verry easy cheep and safe way of disabling speed limiter im sure you have to cut more than one wire to install one of the hks or apexi units listed above so why would this method be dodgy
If you are in Melb I have stock ECU with a Speed limiter over ride connected to it already. For you to look at. This was installed by AVO.
This should give you an idea of what is required.
That's safe and nearly $500 retail for the Apexi unit :P
Wire #53 is commonly known as been able to be cut (according to the SkylinesDownUnder I believe), I never tried it personally as if you have an aftermarket ECU you won't need to do that trick :D
the apexi rsm can be had for $300 direct from the usa..
and i thought that was really cheap.. 300 bux is nothing.
pivot speedmeters are pretty cheap and will remove limiter, cutting no53 is obviously the cheapest but you guys with autos better do a search cause i think its a no no.
I've heard you can melt the limiters by travelling at the max speed (this being 180k) for at least 5 minutes at a stretch...the fun part would be finding a stretch of road that is suitable for 5 mins worth of flat out driving at 180Km/h...That overides them without having to buy a limiter defence cut thing.
Or you can do that on a dyno :(
I heard this from many people not just a few of em and a few people who have actually succeeded in doing so. So its worth giving a try i guess, just run your boost on low and gradually make your way up to the speed ona dyno and leave it there for as long as needed.
Don't know how reliable this is since i havnt done it myself...but worth a try like i said....
i think it is the same wire. have a look at the ECU.. apparently the R34 is wire 29# or something but 32 and 33 has the same.
yes i recon... people are forgetting how Stereos, speakers, Alarms, Tachos, immobilisers are installed.....
no body solders things anymore.... its just snip snip.... and electrical tape it shut....
i think its worth a try... and if its no good.... just tape it back up...
sweet cheers might try it tomorrow ill let you s know how it goes
lol
you seem more keen than the OP...
yep, definately keep us posted and you could be the first to POST a DIY. ive checked and there isnt one there regarding this
  • 6 years later...
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
