Finally results are in.
She punched out 200.2 ATW on 12 psi (although spiking to 12.8) Not bad. But useless.
As soon as i took it out on the street off the dyno and gave it some... Rattling noise. Ping im sure. The 'tuner' was with me at the time, and looked concerned when i stated hey its f**king pinging hard.. he wound back the boost a little and f**ked with the timing.
Still did it at around 11.8psi. He stated you need a decent intercooler... Drove it tonight briefly on the high setting and it didnt ping (very cold out tonight), but it comes on boost in an unstable manner. the dyno readout is pretty wobbly and has a dip higher in the revs. Ill post this when i can. Looks like shit to me. With the standard solenoid grounded permanently it pulled 182kW ATF 9psi and a nice flat curve.. With the Eboost on 12psi its wobbly and looks like shit.
The boost controller is a new Turbosmart EBoost Street. Ive been reading the manuals and its states various options regarding gate pressure and sensitivity. Im sure these could be improved as it spikes considerably. I thought these f**king electronic things didnt spike once set properly.
Seems i now have little to no faith in his abilities or advise so im forced to have it retuned by someone who is trustworthy because i cannot comfortably drive it again without freaking out. Its now set back to setting one with runs around 9psi.
Can anyone please a reputable tuner in Sydney??? I dont care what it costs as long as they know skylines!!! Desperately need some decent advise i dunno who to listen to now
This sucks as this car was absolutely perfect prior and its disappointing to be honest. Its impressed everyone whose worked on it... Im now contemplating ripping it all out and replacing it with the factory setup as before running high mode constantly... Atleast i could rev it and not worry about destroying the motor.... Surely i could run 10-11 psi with a r34 SMIC without troubles??
Current mods
R34 SMIC
3 inch Nismo exhaust
JJR Split Dump/Front
K&N High Flow Panel
Turbosmart EBoost Street....
Cheers,
Matt
https://www.sau.com.au/forums/topic/270319-r33-gts25t/
does it have an aftermarket ecu or are they just advancing the timing via the CAS?
Standard ecu. I wouldnt have a clue as to what you would do if you were adjusting timing (im mechanically impaired). I heard him mumble it, open the bonnet and adjust something at the front of the motor?
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598610
You pulled 200kw@wheels on the stock ECU and a side mount :blush:
The stock ECU should be dumping bulk fuel, how the hell is it pinging?
Adjusting the timing via the CAS is pretty bloody dodgy.
Edited by PM-R33
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598623
+1
You need a decent fmic or a bigger side mount, also what are your plug gaps, at that boost level should be 0.8 or 0.9mm
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598630
no need to reduce the plug gaps, if your coils are good you can (and i do) run 1.1mm all day every day with any sort of power the stock turbo can give you.
To a point of course, i hit 18psi with my standard turbo and it was breaking down, i now have a hi flow and any more than .85bar and it starts to break down.
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598640
ive never heard pinging before. it was an obvious metallic rattling at revs under load. But the AFR's showed at high revs around 10.5 : 1. Its got me f**ked i just dont understand it enough to get my head around whats happening.
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598653
People are running in excess of 200AWKW with an R34 smic - that's not the problem. You need some way of tuning the motor and just playing with the cas doesn't count.
If you can't afford a Vipec get an SAFC and an SITC and get them tuned on a dyno.
Contact Anthony (Guilt Toy) for a tune and the lowdown on your options (may be others in your area but I wouldn't know).
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598886
Another point is that you should never hear pinging with a standard r33 ecu as when ever the knock sensors pick up knocking (usually it is very conservative) it will retard it.
the sound of knocking, its fairly loud? could be heard over the motor revving? this was
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598993
is the engine light flashing when the "noise" occurs? if its detonation, and you can hear it whilst driving, inside the car, surely the engine light will be flashing.
its not something silly like being able to hear the EBC solenoid ?
if its detonating, and the engine light is not flashing, maybe check the ecu and see if it has been attacked. maybe its been fiddled with
is you rev limiter at 6800 or 6900 or what ever the stock limter is? what about speed limiter?
i know my car a few year back on the std ecu, anything over 10 psi, Rich & retard would chime in, and it would run like a fat kid through sand.
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4598995
I didnt notice the engine light. I generally notice and hear every noise and rattle. i dont think ive ever revved it to the limiter. it revved to nearly 7 on the dyno but i didnt hear a limiter. The rattle noise also appeared a little lower in the revs around 4-5 k...
It shows on dyno sheet AFR running down to mid 10's which is apparently rich as hell. my piss weak understanding tells me it shouldnt knock if thats the case? One thing is certain on high mode last night it spikes up to atleast 13 or more. On the low setting it doesnt spike at all. After reading the EBC manual i think i can adjust this with gate pressure etc so it doesnt come on boost as quick etc??
Ill pay anyone who is genuinly capable in there trade and has a good knowledge of skylines. Im tired of pretenders, as this EBC wasnt cheap including the dyno run/tune which was useless as tits on a bull.... what good is 200 ATW if you cant use it safely
https://www.sau.com.au/forums/topic/270319-r33-gts25t/#findComment-4599005
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
