AS V-Spec said tyres and suspension setup have the biggest effect on this. Power delivery also has a part in this but not as much as the other two factors. My toyota has less power than my skyline (226rwkw) but when i had my slightly worn dodgy pirellis on it and very stiff suspension it would snap sideways and wheel spin in 3rd on dry bitumen as soon as it came on boost at about half throttle (~3000rpm). My skyline with drag suspension rather than drift setup has a big turbo (gt3037s) and very soft falken tyres but doesn't go sideways and wheelspin when it hits boost as easily as my toyota. You can put very stiff suspension in a silvia/180 and setup camber and caster for drifting and get it to wheelspin easily in 2nd with relatively stock engine.
If you are just wanting to know how much power your car has as vspec said go to a dyno shootout or something (pretty cheap) or if you want to know how to get your car to do this just speak to a tuning shop and they should be able to advise what mods are needed.
Jamie
i have a rb20det in a siliva.. heaps of camber on the rear.. low n hard.. and if i go from first two second i get no traction what so ever in second and it wil chirp and sometimes with .8bar boost it will kick a bit sideways changing to third... with 1bar it will kick out and spin a lil more but thats with 4.3 diff gears i think.. well at 110 in 5th its about 3800!!!
lol...
i have over 200rwkw.
no loss of traction in 1st or second, if i launch smoothly and then mash it.
If i launch hard then wheelspin all the way till the top of 2nd.
I only have 225's so it does well to keep traction most of the time
but it all has to do with how you work ya clutch
With my SR180 and 195's i could wheelspin at 110km/h for as far as i wanted in the dry (i got a fine on the highway within 20mins of driving with those tyres :( ). Tyres make a phonomenal difference i had 2 difference sets of 235's, once were pathetic and would spin for a fair bit when i shifted into 3rd, while the others would just twitch and hook up well.
To answer your original question i would say 220rwkw with a stockish suspension/tyres setup.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
