Hi chasing a few parts
Brake master cylinder off a r33 gts-t preferably non-abs
guards/shields from behind the front brakes of a r33 gts-t
RHS rear hub assembly(not gtr), mainly chasing all handbrake parts(backing plate,clips, pins, adjusters, shoes, etc sure you get the picture), dont need handbrake cable, calliper or rotor
I'm in Bundaberg QLD 4670, prefer local area, but if willing to post send me a PM with a cost including postage.
Thanks, Graham
https://www.sau.com.au/forums/topic/270336-wtb-r33-brake-parts/
I've got a couple of Brake Master Cylinders, ABS though.
One was from an R33 GTSt Part Number BM44 (came with my R33 GTSt brake upgrade), one came off my 98 R34 25GT Sedan also has part number BM44.
I've now bought a replacement R33 GTSt brake booster which happened to come with a BM44 Cylinder attached, so I have 2 MC's that I want to sell.
PM if interested.
Have shields for front brakes.
Still chasing BMC needs to be similar in setup to one in pic below, rear brake line at front front brake lines to rear.
As for the handbrake assembly shown in an earlier post I need all that is shown in it( the backing plate, shoes, adjusters, spings, pins, etc) all still attached together would be nice but if all the pieces are there I am willing to put it back together.
Let me know prices posted.
Thanks, Graham
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
