oh cool
never had a stalling problem, the stock clutch was slipping when he bought it, so in went the nismo item :P
he bought it with 93kms so he did abit under 10,000kms in 1 year of ownership...which is pretty good considering i did over 20,000kms LOL
  • Replies 75
series 3 (especialy 1998) fetch a higher price
maybe cos its the very last ones to be made before the R34 started rolling out.
series 3 has a better interior in my opinion, the red in the seats and door trims looks hot
not to mention the series 3 gearbox :D
why whats the gearbox got different..
i heard something like they have better synchros or something.. not too sure
what do series 3 have different then a regular series 2
im pretty sure mines a series 3.. 1997 non v-spec
yeah, for series 3 - gearbox synchros were revised.
some of the easier tell tale vspec signs are a finned diff and an active LSD light in the dash. on a side note - vspec weighs a bit more.
vspec is also a tad lower and technically is meant to be a few thousand more :D
yeh i know how to tell for v-spec.. but how do u tell for series 3 ??
are series 3 only v-spec ??
Main differences between series 1 and series 3 are:
- Xenon headlights
- Deeper/fatter lower lip
- Red stitching on interior seats/door trims
- Right hand rear tailight has a red fog light in place of reverse light
- Stronger synchros in gearbox
- KR4 silver was not available in Series 1
- KL0 silver was not available in Series 3
There may be more but those are the most common...
- Xenon headlights
ahh sweet mines a series 3 then :)
i got the:
-xenon headlights
-red stitching
-d/s fog light instead of reverse light ( switch found lower left of steering wheel coloumn )
-front lip is fatter and long ( scrape up my drive way :D
- mines in black ( heard rare color to find on series 3's but i dont know )
- red stitching on steering wheels
- hole next to p/s front blinker ( which KR4 said is for oil cooler )
i think thats all. but cheers on the syncho information i didnt know about that :)
hey KR4-GTR when u fitted the pfc.. how much power gain did you get from it ???
someone told me depending on safe tune or heavy tune it can vary from 30-50 kw gain
now i dont believe that.. but seeing as u have just fitted yours, do you know how much it would be
i have 217kw at all four wheels
- cat back exhaust
- apexi air filters
- boosted to 14 psi
and now the pfc..
im getting it tuned next week at Gas Motorsport.. or do you guys know anyone better then this in the sydney region
cheers
- cat back exhaust
- apexi air filters
- boosted to 14 psi
and now the pfc..
cheers
hey mate, it was 178kw @ wheels originally before tune and power fc.
now it is 222 @ wheels @ a SAFE tune - 12psi. i told them i wanted economy over power.
would be interesting to see what you got if you were to put a power fc in.
post results please!
on a side note, just filled up again - i didnt leave it until it touched the E but i did the math and i would have gotten around 470 to the full tank, daily driving.
after research, i've also learnt that a r33 gtr tank is 65 litres. a r32 gtr tank is 72 litres! :)
hahaha.. thats really good to know thanks !!!
when i get my car back from the tuner ill check mine out too.. atm its terrible on economy :ermm:
will post results.. i changed my mind tho.. im getting it tuned next week at CRD ( Croydon Racing Developments )
they seem to be the skyline experts lol
i will post up my results
  • 4 weeks later...
hey dude, did you get the car tuned!?
results!?
what type of kms are you getting to your full tank on normal driving with abit of push every now and again?
hey mate, still around 400+ on average with a few boots. depends how hard you push it though of corse.
driving very sensibly - 470 to the tank.
hope this helps.
cheers.
Edited by KR4-GTR
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
