Guys you could always go the back way to wakefield rather than up the hwy. much more interesting drive.... unfortunately, I won't have my car til march 04. Also, try the road down to Kiama through kangaroo Valley, fewer cars on the road and better for punting in my book.
Cheers
  • Replies 52
Originally posted by SilverSlyder
At this stage i should be able to make it.  Coast crusie would be good, havn't been down there for a while.
Cool, It'd be good to catch up with you again.
TomR33 - are you still around :P You coming too?
The more the better.
J
Hi Jay, yeah I'm still around but I can't make it. I'll be out of Canberre for the weekend. It would be good to catch up with every one.
By the way Jay, I got the wideband oxygen sensor and soon will be doing some experiments with the R32 ECU, I'll let you know how I go.
Tom
Good to see your still kicking around Tom ;)
Looks like their planning another cruise in a few weeks/months, so we'll see what goes then.
Good stuff about the wideband sensor, it'd be good to see how you go. Let me know if you need a hand (tuning while someone drives etc).
Cheers
J
the meeting place is at the caltex in QBN. the one near kfc. i think we will decide where to go when we all meet up. some want coast ,others want wakefield , so lets make a decision after we see how many turn up????. tom ,good to hear from you again , haven't seen u in a while....what about the rest of elitesport????.
john ,oppy ????
remember the time is 12.00 with a 12.30 depart time on this sunday the 2nd.caltex QBN.
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
