AS NEW CONDITION, THIS MODEL IS UNRELEASED IN OZ, NOT TO BE CONFUSED WITH DEH-P80RS!! THIS UNIT ALSO FEATURES A COPPER CHASE FOR CLEAN PUREST SOUND QUALITY. THIS MODEL IS ONLY AVAILABLE OVERSEASE BUT WORKS WITH AUSTRALIA AM/FM RADIO FREQ WITH NO PROBLEMS.
DEHP800PRS
Pioneer Premier DEH-P800PRS CD Receiver with High Quality Audio Design and Copper Plated Chassis Model
DEHP800PRS Part No. DEHP800PRS
Supertuner III
24-Station/6-Button (18FM/6AM) Presets
BSM (Best Stations Memory)
Local Station Setting Selectable (4-Step)
Digital Radio Capability:
HD Radio Ready External Control Only
XM Radio Ready:(GEX-P920XM Required)
Sirius Radio Ready: (CDSB10/SCC1 Required)
CD Player:
1-bit D/A Converter 24-bit Burr Brown
CD-R/CD-RW Compatible
AGC (Automatic Gain Control)
Disc Title Memory
Disc List
Track Title List
CD Text CD Text
MP3 Playback Compatibility
Codec Support MP3, WMA, WAV, iTunes AAC
Bluetooth Capable:(CD-BTB200 required)
iPod Control Capable: (CD-IB100II required)
Additional System Expandability:
IP-Bus System Control
USB Control Capability Adapter (CD-UB100 required)
Multi-CD Control
DVD Control
Display Output
Built-in Auxiliary Input (Rear)
Optional (IP-Bus) Auxilary Input CD-RB10 or CD-RB20 required
External Unit Control 2
Display Features:
Auto Slide Motorized Flap Face
Display Type White Organic EL (OEL)
Dot Matrix OEL Size 160 x 48
Multi-Language: English, French, Spanish
Button (Key) Illumination: Switchable Blue or White
Audio Features:
Built-in Speaker Power MOSFET 50W x 4 (22W x 4 RMS)
Equalizer Dual (L/R) 16-Band Graphic
5 Equalizer Presets
2 User Equalizer Settings
Loudness
Advanced Sound Retriever (ASR)
DSP
Auto-EQ (With Mic Included)
Auto-Time Alignment
Listening Position Selector
BBE Digital
Electronic Balance/Fader
Source Level Adjuster (SLA)
Three-Way Crossover Network
High-Pass Crossover (HPF) 50/63/80/100/ 125/160/200Hz, 0/-6/-12dB/Oct.
Subwoofer Crossover (LPF) 50/63/80/100/ 125/160/200Hz, -6/-12/-18dB/Oct.
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (5V), 100 ohm
General Features:
Volume Control Rotary Commander
Operation Mode Rotary Commander
10-Key Card Remote Control
Wired Remote Input
Cellular Mute
Detachable Face Security
Face Case (Included)
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
