two ways to interpret a Hicas warning:
1. there is a system fault
2. it's time to replace it altogether with a lock so it handles better.
mine didn't have a fault but i went to 2 anyway. hope you find the issue.
Cheers
x2 Lock Bar my Hicas died and the lockbar makes the car handle soooo much better :):)
currently highway driving, not turning or anything, and the HICAS warning came on. What problems could it indicate? Knowing my luck its either the sensor has failed, or it wont come back on when i start driving again...
Thanks
Hey buddy, 5 months ago when i first bought my car i had that prooblem too sometimes the hicas light turn on when i go over bumpy roads and also my deck loses power.
The next day i found out that the plug to the battery was really lose (i couldnt even start the car and i was shitting myself :)) so got it fixed and the HICAS warning light never shows when i drive anymore.
Hope this would help you because im not too sure what the problem was, i am just assuming that the plug to the battery is loose, good luck fixing
cheers
long
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
