Hey guys, this is just an Expression of Interest for stripping a R34.
Things NOT included: Engine, and Manual Gearbox etc (Shehan had dibs on it) :( and ofcoarse the system.
Everything else is up for grabs guys.
As i said its just an expression of interest to see if it will be worthwhile for me to start ripping the car apart or not.
Goodies?
Carbon OEM Hood, has some damage on it though.
Kakimoto Stainless Steal Catback.
Splitfire Coilpacks
Xenon Headlights ( Will sell pair unless you can organise for a person to buy a left if your after a right vice versa )
Other than all this, everything else in the car is stock
1999 Model Nissan Skyline 25GT Manual 2 Door.
White
Shell not for sale.
Thanks guys.
And please forgive me if i reply late to PM's or Posts (max delay 12 Hours)
Planning to Strip next month.
Note: No Bidding on items
Some of these parts will also be on eBay next month and will update the thread once i start to rip it apart and catalogue all the parts available.
MRXTCZ
https://www.sau.com.au/forums/topic/270408-eoi-stripping-r34-25gt/
  • Replies 62
Just incase people are confused, everything else in the car is up for grabs aswell.
Reason?
I got into an accident, and need to strip the car to make some money back to pay off the loan :(
So, interior panels eg. door panels, seats, floor mats, a/c surround, a/c unit, engine bits and peices just not the whole engine itself.
MRXTCZ
VikZ
Thanks for holding the manual kit for me, but it's up for grabs because I can't take it anymore.
I've no money left to work on the car!
Cheers!
p.s. however i am interested in the front passenger side panel if it's for sale. thanks.
how much for coilpacks? will buy if reasoonable price?
how much for those interior trims around the headunit that always get scratched (if yours arent scratched)
EJD001
Wouldnt have a clue mate, do a search and find out.
OKBANANA
Pm recieved and noted name down for the gear surround, a/c vents and surround and AC unit.
ash_29
If OKBANANA falls through the item is yours, but im pretty sure he wont
imnotwearingpants
Condensor is still available and will let you know a price closer to dismantle date
XKLABA
Number plate lights still available, closer to dismantle date.
SHANE666
No worries dude :P
Manual Conversion kit still for sale!
Keeffy
As Daniel said, cars NA
Natho33
Coilpacks will be let go for $325, less than a year old Splitfires.
Resh
Sorry dude didnt come with the pop up LCD
Hypnotik
I'll have to get back to you on that one.
It is the same as the GTT, just wanna see if they wanna sell drivers and passenger as a pair.
But will let you know asap.
Nushtek
$325
Galla_4
Speedo cluster, i will let you know the price asap
I'd probably PM you :)
For everyone else who has PM'd me, i have replied so check your inboxes.
I've got a list of what people want at home as i am at work right now, and will update that list asap.
I wanna make this as less painful as i can, so i just wanna catalogue the parts, and as soon as you got the money ready i will rip it out and hand it to you :)
MRXTCZ
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
