anyone know what could cause this??. The 4wd light comes on, then goes off as normal.
I was at a drag race and people told me that only the rears were spinning. This explains my awful launches and slow 1/4 mile times.. the track was untreated and I was using much too hard yokohama advan slicks. Got a 13.001 @186kmh and my girl is really capable of more than that...I was about the only person not using mk drag slicks...
https://www.sau.com.au/forums/topic/270426-gtr-drive-problems/
Open your boot, take off the bit on the driver's side and check your ATTESSA fluid level
just checked it...the levels fine(a bit high), spun the wheels and the torque gauge shows power to the front.....my assistant said the fronts did nothing
Just because wheels don't spin doesn't mean you have a problem. If anything, the fact that the rears break traction is the problem.
Go and read through any of the hundreds of threads that explain how the ATTESSA 4WD system works. Then decide if you actually have a problem.
I know how it works...my other gtr works a treat...this one doesn't...
it could be so many things. search for attesa diagnostics either google or in the forum and run the diagnostic sequence then check the diagnostic light flashes to see if any fault codes come up. if they do follow up whatever they indicate is not working. if nothing comes up check the basics first. do you have the same sized tyres all round? are all the wheel speed (ABS) sensors intact? they can be easily damaged as they are quite exposed. you've already checked the fluid level. can you hear the pump prime when the car is turned on? go to a workshop and get them to put a pressure gauge on the pump. good workshops will know how to test the awd and know what type of pressure the pump should be outputting under certain conditions.
anyway, start by checking for fault codes.
no fault codes...no nasty noises...pump runs..4wd light goes out...fluid level good....
it has uprated lsd's, and whoever wired the rear fog light managed to somehow give the brake light permanent live...so the brake lights come on when the ignition is off and if you turn the ignition on to listen to the stereo...you get that bloody awful buzzer all the time...
maybe they have tapped into something they shouldn'e have !
emailed the people who tuned it and dyno'd it before I owned it..they only have a 2 wheel drive dyno and said they think they either remove the abs fuse...or disconnect one of the front wheel speed sensors....
now my car does have very very heavy steering, but I put this down to a dodgy speedo conversion when it was brought over from japan...
Heavy steering? Dodgy speedo conversion?
Japan is in km/h, what has it been converted to?
Heavy steering may indicate the HICAS computer has been disconnected, but that is the 4 wheel steering system, not sure which models get the heavy steering, I know the R33 does...
unclipped the connector by the bonnet release.... turn on ignition and attessa pump runs constantly...reconnect.turn on ignition and nothing....should it prime when the ignition is switched on ????? is it usually so quiet you can't hear it..but can only feel the vibration?
it's been converted to mph....not sure how it was converted but the car has a full cage so think getting the clocks out might be a problem??
just lifted all 4 wheels, the fronts spin when in gear but you can stop them with your foot.
I disconnected the clip under the dash and this did not cause the pump to run constantly...... which relay is it that controls the attessa pump...the blue or the black???
Am i correct in thinking the pump should be on constantly when the clips disconnected..???
just bled the system, still no power to fronts....they can be stopped with your foot !!... tried to spinning the rears but the fronts still didn't perform... no error codes.....pump seems to work fine.....levels good......what it is?? pleasse somebody......
+1 rooted clutches in transfer case. They pulled the fuse before putting it on a 2wd dyno without bleeding pressure off to the transfer case (or mech. disconnecting it). Difference in steering may be because they didnt plug the speed sensor back in, Hicas uses it.
If the fronts are spinning under these conditions, then my opinion is that the ATTESSA is working. What does the torque-split gauge say?
AFAIK, the front diff is open, so it would be possible to stop one side, and the other side would continue to be driven. Is that what happens?
If you remove the fuse (in a R33), the car goes to limp mode (I believe) - that makes it impossible to run it on a 2WD dyno.
Just torque transfer by fluid coupling in the transfer case can produce the same effect.
I would suggest checking the pump again, and seeing if the pressure you are getting out is correct, not just hearing a noise.. R32 manual states between 294 and 490kPa (43-71psi).
If you are getting the correct pressure and still no drive, then clutch pack..
The bleed nipple under the pump....turned on the ignition.....about 10ml came out...then no more.... the pump did not run constantly..as I thought it was supposed to with the bleed connector disconnected..should this bleed fast, slow or should I not have done it?
When you turn the ignition on and off the actuator thing clunks and sometimes the pump comes on...not often though..
When I bled my system, you would turn on the ignition, and there would be a slight delay and the liquid starts coming out, it wasn't that slow but it took a while to get through the tank in the back of the boot.
I turned the ignition on and off at least 5 times to make sure I gave the pump a break, there's a tutorial on this somewhere.
The fact that its not pumping doesn't sound right...
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
