I'm currently putting together an RB20 with a HKS 2530 and injectors/fuel pump/fmic/z32 AFM/eManage Ultimate. I put the new turbo and FMIC on and have taken it for a test drive to make sure I didn't break and it seemed to work ok(slightly laggier than expected). I'm not expecting it to run properly without a tune and the new injectors/fuel pump but I got a very bad misfire at just under 5000rpm at 10PSI.
Is there anyway to test if this is due to lean out or whether its a spark issue? I don't wanna waste money getting new coils if I don't need too but if its a lean out issue then that won't be fixed until the tune, and I want it all together by the time I get it tuned.
Edited by Kwyjibo
https://www.sau.com.au/forums/topic/270465-lean-or-spark-problems/
Go and get it tuned FFS.
Thats the only way you will know for sure.
How can you possibly expect the engine to function correctly after all those mods.
Next you will be posting "Why did my engine blow up?"
Ummm, if you read my post you would understand that I took it for a TEST drive to ensure the turbo and FMIC was running smoothly(no other mods have been put on yet). I was just wondering if there was a way to tell whether I will need new coils or not BEFORE I spend $700 on the tune I am going to get before I blow my engine. Hence where I said ''I'm not expecting it to run properly without a tune and the new injectors/fuel pump''
I understand there are a lot of fairly clueless people on here but I clearly stated in my first post that my plans are to get a tune and I know my car is not going to run properly until then, and it will be off the road until then. I like to test the car inbetween each mod(obviously I won't be able too with injectors and AFM) to ease troubleshooting in the long term.
I just wanted to know if there is an easy way to tell the difference between the misfire so I don't have to take the car out again till its tuned.....
Please read my full post next time before posting, anything resembling and answer to my question would have been nice as well.
Edited by Kwyjibo
The only way to diagnose it properly is to get on the dyno.
Simple.
Im sure the tuner knows more about this sort of stuff than you do.
If you think its coils, get some coils off another car that you know are working and test. Check for any boost leaks ect
Other than that you cant do much until you get it on the dyno.
And of course its running lean, you have just put a bigger turbo on that flows a hell of a lot more air than stock the ECU cant feed enough fuel to it.
The ECU is most likely hitting R&R.
Clueless people indeed.
Thank you thats what I thought. I will just buy some coils as mine are getting old anyway.
I'm not clueless, I just don't have a lot of knowledge apart from what I read on here, which is why I ask so I can learn these things. No need to be rude about it.
I know it would be running way too lean and well above the current tune(even though I'm running way less boost than before), but as I stated all I wanted to know is if there is a way to tell the difference between misfiring due to learning out, or misfiring due to ignition issues.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
    • Yeah, that and throwing away opened, part used, closed back up bottles has got to be bullshit. Brake fluid sits in not-very-well sealed master cylinder reservoirs for literal years and keeps working (albeit we know we should flush it every couple of years - it actually still works). Anything kept in a bottle in the shed with a tightly capped lid has got to be a million times better than what has been in the car for the same length of time.
    • Wait, they're claiming UNOPENED fluid has a shelf life of only 18 months?
