The following parts are located in Sydney but I can arrange postage.
R32 GTR Twin Turbos with dump pipes, manifolds & heat sheilds. Very good condition never boosted no shaft play no leaks. $550
R32 GTR Plenum. $100
444cc Injectors. $300
GTR Fuel Rail (injector feed). $50
R32 GTR 6 Pistons and Con-Rods. one Piston is no good the rest are fine, conrods are all good. $100
Used EXEDY (push type) single plate clutch heavy duty good condition to fit R32 GTR. $250
GTR AFM Air Flow Meter in good working condition (Tested). $150
Standard RB26 Cam gears. $50/pair
R32 GTR Complete Rear Tail Lights with covers excellent condition. $200/pair
R32 GTR Machined Flywheel. $100
R32 GTR HICAS computer. $50
R32 GTR 4WD Computer. $50
R32 GTR Intercooler works perfect. $200
Injector wireing with cover. $100
Coilpacks with loom $150
Twin HKS BOVs complete with Top mount pipe and hoses $350
NISMO cluster 320Km has 55000kms on it. $400
https://www.sau.com.au/forums/topic/270480-r32-gtr-parts-for-sale/
Hey Guys The following is still for sale
Hey Guys The following parts are still for sale
R32 GTR Twin Turbos with dump pipes, manifolds & heat sheilds. Very good condition never boosted no shaft play no leaks. $500
GTR Fuel Rail. $50
R32 GTR 6 Con-Rods excellent condition. $100
EXEDY (push type) single plate Brass button clutch good condition to fit R32 GTR only 10,000 Kms traveled. $250
Located in Sydney (can post)
  • 1 month later...
    • Probably too late to reply to this, but worth a try. It's not calliper flex, the calliper as a whole is moving so it has to be calliper mounting bracket flex.  Calliper mounting brackets are designed to stop the calliper rotating, they don't need to be designed heavy duty to stop the calliper moving in and out.  Whatever it is is not the major cause of poor pedal feel, the outer pistons are moving towards the disc rotor the same amount as the inner pistons are moving away from the disc rotor.  Hence no change in fluid usage, what extra fluid is needed to move the outer pistons is recovered from the inner pistons. For a calliper to move as a whole by far the most common reason is the rotor is not perfectly centred in the calliper.  The first thing I check is that hub face is perfectly clean, bare metal, where the rotor hats contacts it.  Then I check the that rotor is firmly held in place by at least 3 wheel nuts (or equivalent). If all of the above are confirmed to be in perfect alignment then I would check the piston sizes and ensure that the 3 inner pistons and 3 outer pistons have matching diameters (eg; 28/32/36mm).  I have seen a no name 4 spot calliper that had 1 of the 4 pistons a different diameter. Maybe I missed it, are both the callipers exhibiting the same problem? I would remove the transfer pipe and inspect it to make sure that there are no restrictions. Maybe you already have but if not I would return them with the video and have them confirm all of the above.   Hope that helps Cheers Gary
    • If you have the original log book and it didn't have a chassis number quoted, then no money required.  I have "rechassied" a number of race cars, no problem as long as you have the original log book.   Cheers Gary
    • Well the good news is that it won't run any worse with an atmo bov than it does with no bov, I've owned a few Nissans over the years (r32, s15 and now r33), the stalling issue caused by a bov or no bov while still having an afm is easy enough to live with, most people get used to driving them and just feathering the throttle when you come to a stop to avoid it stalling. Changing to a proper ecu with a map sensor is ideal but in the short term I'd just slap in the bov if you really want the whoosh sound. I looked into the pass through type maf like the R35 one above but decided against it as the amount of oil and crap flowing through the hot side would mean you'd have to clean it often to keep it working.
    • Build an 800hp motor. Make it as bullet proof as you want, you WILL still break things. Like, the rest of the car. Heck, even as a dead stock car, things will still break, but the more power, the more everything else will let go easier. From gearbox gear sets, to extra stress on the chassis/mounts, more stress on diff, axles, tailshaft, even the suspension mounts. Check out the motorsport build that last year went to a Bosch motor sport ABS setup, and now can brake so damn hard it's twisting mounts for suspension/subframe etc. Now if the brakes can do it, imagine what happens with super grippy tyres and 800hp in a low gear...   Shit, I'm presently out fixing the girlfriends daily driver that rarely sees past 3,000rpm and is used to cart the dogs around in. Everything WILL break. If you don't want it to break, don't drive it. And then laugh, as it will still break without even being driven!
