hey guys
this morning i went outside to find 1 of the cars doors was slightly open.
i tried to open the locked( or so i thought) drivers side door and it just opened. no alarm. no nothing
the motherf**kers took the centre roof light( did a good job too, took their time unclipping it etc)
also took my little sisters portable dvd players.
i know they didnt take much but there was no damage to the cars doors or the locks so i have nfc how they got in. and the car was locked
beware northern suburbs peepz!
https://www.sau.com.au/forums/topic/270573-motherfkers-broke-into-my-mums-car/
it was a ford territory
i guess we were lucky
turns out 3 other cars got broken into in our area.
lol @ insurance
think i forgot about the 5 genuine picaso painting being taxed, as well as my genuine collection of rolex watches
LOL
i thought the same thing
o opened the door looked around
and saw the wires hanging and thought what the f**k?.. they left the glasses, phone and 1/4 hp air compressor in the boot and took the roof light and a pair of dvd players that were pretty much f**ked
maybe so they done get busted while the door is open. take the light out.
and just go by feel. and leave the door ajar when they leave so no sound of closing the door. and if your hear anything, you look out at the car see no light on nothing looks sus .... right ?
untill morning
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
