Girlfiends little mirage is using heaps of oil? normally holds around 3.3ltrs but the last 2 services ive done on it ive only taken out about 1.5ltrs?? A coulpe of times ive had to give it a massive top up because the engine light has come on. Took the plugs out on the weekend and they where all fouled with burnt oil and gunk.
i service it every 5000km started with 10w-40 oil but moved up to 15w-40 becuase of the oil loss.
Car has done around 170000kms
Any ideas on why this keeps happerning any help would be great
Thanks.
https://www.sau.com.au/forums/topic/270603-98-mirage/
I've noticed the same thing with the GF's Corolla, 10 or so years old, 140000km and burns oil like no tomorrow! pretty sure that one has 20w50 (albeit cheap shit united brand oil lol), not sure about when it had a proper service last, it blows a heap of white oily smelling smoke on cold start then is fine as far as I can tell. Surely plugs wouldn't make that much of a dramatic difference?
https://www.sau.com.au/forums/topic/270603-98-mirage/#findComment-4602065
It really depends on how it was serviced in its life. Heck my corolla is now knocking on 300000 km with original engine. Just done a new water pump ( old one started leaking - Bastard to replace ) and a timing belt for good measure. Thing only uses a litre every 5000 + kms and not all of that is getting past the rings. Crank seal is leaking . Yet some pretty new cars you see these days are churning out Blue smoke when the car is less than 5 years old.
https://www.sau.com.au/forums/topic/270603-98-mirage/#findComment-4602092
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
