Girlfiends little mirage is using heaps of oil? normally holds around 3.3ltrs but the last 2 services ive done on it ive only taken out about 1.5ltrs?? A coulpe of times ive had to give it a massive top up because the engine light has come on. Took the plugs out on the weekend and they where all fouled with burnt oil and gunk.
i service it every 5000km started with 10w-40 oil but moved up to 15w-40 becuase of the oil loss.
Car has done around 170000kms
Any ideas on why this keeps happerning any help would be great
Thanks.
https://www.sau.com.au/forums/topic/270603-98-mirage/
I've noticed the same thing with the GF's Corolla, 10 or so years old, 140000km and burns oil like no tomorrow! pretty sure that one has 20w50 (albeit cheap shit united brand oil lol), not sure about when it had a proper service last, it blows a heap of white oily smelling smoke on cold start then is fine as far as I can tell. Surely plugs wouldn't make that much of a dramatic difference?
https://www.sau.com.au/forums/topic/270603-98-mirage/#findComment-4602065
It really depends on how it was serviced in its life. Heck my corolla is now knocking on 300000 km with original engine. Just done a new water pump ( old one started leaking - Bastard to replace ) and a timing belt for good measure. Thing only uses a litre every 5000 + kms and not all of that is getting past the rings. Crank seal is leaking . Yet some pretty new cars you see these days are churning out Blue smoke when the car is less than 5 years old.
https://www.sau.com.au/forums/topic/270603-98-mirage/#findComment-4602092
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
