I am interested in buying a Bilstein Suspension Setup for my R33 if anyone has some they would like to sell let me know. I would prefer new especially if someone has purchased the Sydney Kid setup and changed their minds or would prefer a firmer ride. I can trade my as new Greddy Coilovers with a cash adjustment either way depending on what setup you currently have to offer.
I am located in Adelaide but can organise a courier no problem
Please pm me or SMS 0404998591 with details
Thanks in advance for replies
i am intersted in buying the coilovers.....some more info on them and price if youre interested
Ta
Gday Nigel, how you doing mate?
Dan from ELITE RACING on SAU QLD sells the Bilsteins as well. He uses King Springs. Here is the link to the site, you need to register with SAU QLD first:
http://www.sauqld.com/ipb/index.php?&s...ic=809&st=0
And here is the text from the site if you cant log in. Hope that helps!!!!! Dan is a great guy and extremely helpful.
Hello All.
I have set up Suspension Kits to suit R33 GTST. This product has been tested by many and will greatly improve your vehicles handling and general road feel.
I am using a progressive rate spring on the rear and a progressive rate spring on the front.
The Bilstein shocks are well known for their performance around both track and street applications.
I will be setting these up as both standard circlip style with grooves cut into the shock and then also as a coil-over if you want fine adjustment. Also more springrates are available with the coil-over option, this option is only recommended for advanced users or for people looking for a lower ride height but still with the handling that can be obtained by using the Bilstein/King spring combination.
I have chosen not to use the Whiteline Springs in this application as they have been proven to be doughy compared to the superior King spring.
The parts to the kit can be purchased seperately if desired so I will put up the individual prices.
THE BILSTEIN KITS DO NOT COME WITH TOP HATS. THE FACTORY ITEMS ARE REQUIRED TO COMPLETE FITMENT
SAUQLD Member Prices
Bilstein Shocks (Pair) - $485
Shock Boots + Bumpstops (Pair) - $60
Springs (Pair) - $120
Swaybar - Heavy Duty (Blade Adjustable) - $200
Swaybar - Heavy Duty (Non Adjustable) - $180
Front Upper Control Arm Camber Bushes - $230
Front Castor Rod Bushes (Offset tube for Adjustment) - $90
Rear Upper Control Arm Camber Bushes - $120
Pineapples for Rear Crossmember - $80
Non Member Prices
Bilstein Shocks (Pair) - $528
Shock Boots + Bumpstops (Pair) - $65
Springs (Pair) - $132
Swaybar - Heavy Duty (Blade Adjustable) - $220
Swaybar - Heavy Duty (Non Adjustable) - $198
Front Upper Control Arm Camber Bushes - $253
Front Castor Rod Bushes (Offset tube for Adjustment) - $99
Rear Upper Control Arm Camber Bushes - $132
Pineapples for Rear Crossmember - $88
Unfortunately because these units are modified, they are non-returnable unless there is another buyer for them.
Regards, Daniel
  • 1 year later...
Hey mate, GTS or GTSt? Do you know if R34 GT Sedan Suspension would be suitable?
I've already got a good price lined up for a set of JIC Coilovers which is why I'm looking at selling my current set up.
30mm Lowered King Springs and KYB Shocks. My mechanic tells me they're eyelet connections. Done 20,000kms on them, no track work, recent wheel allignment at Fulcrum confirms that they're all in proper working condition. PM me if interested :)
Cheers
Nathan
