Hi all,
Currently trying to get the oil filter of cheff stageas wags for him and it seems as if theirs a bracked or something on the side/next to it that stops it from comming loose?
Is this correct if so whats the go with removing it to change the oilfilter?
Its a stock setup no filter relocation kit or anything :(
Fast replys would be good :banana:
Cheers,
Chris
Sounds like the oil pressure switch is in the way? With rb26's you pretty much need to attack the oil filter from underneath with a oil filter wrench or another type of oil filter remover, normal oil filter removers you would normally use on a commodore just aren't very effective.
How? The transfer case or front diff is below the oil filter on RB26's, there is nearly no room to go in there from underneath.
I had several people attempt to remove my oil filter, tried a few oil filter wrenches and removal tools, eventually a very strong mechanic just put his hand in there and was able to remove it >_<
Hopefully your one hasn't been done up super tight...
last two I have removed, it was a long screwdriver, through one side out the other and use that to get it started..
made a hell of a mess.. almost thought i had broken my hand trying to get the bastard undone..
next time will be the last, relocation kit incoming.
to undo it properly you need the three pointed claw type attachment that grips onto the end of the filter.
I do mine all the time - pop on some rubber gloves for non slip grip and remove it; also stops your hands gettin thrust against sharp objects in the engine bay lolz
try a filter like knn with a nut on the top so you can remove it with a ratchet next time.
If you have one of those stock Nissan/Pitwork filters on there then the screw driver trick won't work lol as it does stick out far enough, we tried a belt, to no evail, we also tried my very strong mate who couldn't get it off, we ended up getting a 1/2 inch drive oil filter wrench that combined with my strong mate was able to finally wind it off. the oil filter was half twisted around so it must have been on pretty tight. However there is a relocator in place now so i will have no more dramas like that
Did it come like that from Japan? I had a super small filter (not a Z143A, same thread about less than 1/2 the size, made it more challenging) and it had a metal exterior that got damaged by the time it was out....
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
