I have got a set of standard R34 GT coupe wheels
205/55/16
2 Rims have Yokohamas
2 Rims have bridgestone
Fronts are as new
Rears are still very good
Asking 300 O.n.o
Located in brighton melb
https://www.sau.com.au/forums/topic/270668-standard-r34-gt-rims-and-tyre/
  • 3 weeks later...
average condition for a 10 year old set of rims
no buckles cracks on the rims
only damage to rims is light gutter rash
Front two tyres are good with good brand althogh have camber wear
rear 2 have tread although they are worn a bit.
let me know if yours interested.
look great on 32s and 33s
hey bud as discussed when i came to look at them i dont think the tryes are any good they would not pass roady my offer of $150 is still there. up to you if ya wanna sell them quickly give me a tingle on 0401484707 cheers otherwise good luck
benzino no pics, they are the standard R34 GT wheels that everyone has
If you look closely some have gutter rash
from distance they look fine
the standard silvery grey colour
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
