for 17x8 u can go with a 205/45r17 for a stretched look to 245/45r17 which i think is over kill.
for the rims i've had in 17x8 i tend to run 215 45 r17 always although 225 45 would be a more comfortable fit. if you have 17x8 in the rear as well i'd probably go 235/45r17 max.
215 45 17 and 235 45 17 are a more common tyre these days in the 17s which make them cheaper + more available.
Now I use 235/45 R17 for the front and rear with Toyo proxn4
What is the max tyre for 17X8? 245/45 R17?
I plan to use Federal 595-RSR~
What is the best match?
well, with those tyres, id run 225/45's providing ur not running much over stock, and ur looking for both cornering/line grip.
if ur finding its hard to put the power down currently u could go a 235/45 at the rear.
Ok~
I will try 215 at front and 235 at rear
If you have the same size wheels all round then I would recommend satying with the same size tyres all round, the reason is so that you can rotate from front to rear for longer life as the rears will normally wear quicker on a rear wheel drive car (unless your alignment is out).
Depending on what you want out of the tyres, most manufacturers will say that you can safely fit anywhere from 225/45R17 to 255/40R17 on an 8" wide wheel (although this can vary between brands).
Personally I would recommend staying with 235/45R17 all round. :blink:
yeah I would probably got a 235 all round. I used to run 235/45/17s on my 32 GTST all round on 17X8 +30 blitz wheels and they fitted fine. I personally wouldn't go wider than 235 on an 8 inch rim either.
Looks like you had plenty of negative camber on the front in that pic... Looks very neat (I'm a little bias towards R32 GTST's) :nyaanyaa:
Baron~
How about the track performace for 235/45/R17 all around?
That depends more on the type of tyre you get rather than the size... If you get a cheap street tyre and take it to the track you probably wont be happy, but if you buy a good quality set that can handle the abuse of track work you wont regret it.
In almost all cases if you want to do track work, your best bet is to get another set of wheels and fit "track only" tyres to them... Like Bridgestone RE55's or another fairly soft compound semi-slick.
But if you just want the one set of tyres to do everything (good street traction, wet control and reliable grip / life on the track) then you should look for something along the lines of the Federal 595RS-R, Falken RT615, Toyo R1R or another intermediate level "street friendly" semi-slick.
would you believe it was completely stock suspension wise in that pic! stock arms, bushes, shocks the whole lot. so no neg other than whatever was standard. the wheels were sitting nicely flush with the front and rear guards and it had a good ride height too. they really made the look of the car. great rims.
you can see in the on track pic it's a bit lower as I'd just installed some teins.
and like you said, tyre performance on track has little to do with size and everything to do with type of tyre. a 235 semi slick will far outperform a 265 cheap road tyre. those particular tyres were pretty average falkens. :dry: but I did love those rims on that car. I actually pinched them off my soarer and then bought some volks to go on the soarer in it's place. lol it looked pretty funny on GTST wheels for a few days.
and like you said, tyre performance on track has little to do with size and everything to do with type of tyre. a 235 semi slick will far outperform a 265 cheap road tyre. those particular tyres were pretty average falkens. :( but I did love those rims on that car. I actually pinched them off my soarer and then bought some volks to go on the soarer in it's place. lol it looked pretty funny on GTST wheels for a few days.
Hmm, must be the angle of the driveway its sitting on then... Or just my eyes :sick:
I love those wheels too, they're Blitz R series 1 arent they?
I have been trying to con my mate into selling me his for ages, but he loves them because they sit perfectly in the guards and are pretty light... We just painted them black and they look awesome on a silver car...
yeah they are blitz, are forged, and are pretty light. not sure if they're the same as your mates. I think his are a different type of blitz wheel that was a bit more popular than the ones I have (had!). they all look good though. Blitz made some great wheels over the years.
You can run whatever size the particular tyre manufacturer recommends.
we run 17x8" wheels on the race car with 245/45/17 in yoko or khumo, but bridgestone recommended 235 only. the manufacturer knows better than the people on SAU :P
Im pretty sure they are the same (not that it really matters :)) this is what they used to look like before we painted them (pic attached) :)
I will go Federal 595-RSR
If I dont focus on tyres life, just on performance
The best tyres still use 235/45 R17 all wheels?
Thank all suggestions~ :)
Yes... Definitely.
we run 17x8" wheels on the race car with 245/45/17 in yoko or khumo, but bridgestone recommended 235 only. the manufacturer knows better than the people on SAU ;)
Good point Duncan - I can tell you that Federal list 17x8's as the ideal fitment for 235/45R17 595RS-R's :)
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
    • I'm far from an expert, but for sticking bits of metal together occasionally I got a MIG, the biggest one I could get with a 10a plug (because while I have some 15a GPOs around, they are not everywhere).  Also, because I get through SFA, I just buy the small disposable gas bottles at Bunnings, I'm not opening a BOC account to get through 1/10th of a full size bottle each year
    • FWD is different though.
    • Ignore the BOV / recirc valve question. You have an NA and shouldn't have one. If there magically is one though... It should be removed, though it shouldn't really effect it in the way one will for a turbo motor with it venting to atmosphere while running an afm.
