Need Help On My R32 Gtst
As Jamie said more details on the car would help.....but an o2 sensor change might be in order, a lot of cars with that issue get that done & it's resolved pretty easily
Oh ok,
Well I got Apexi pod filer, down pipe, high flow cat, cat back. And that's about it....
All engine stuff and turbo is all stock. Havent tweaked the boost up either.
I tohught it was spark plug so I changed it like a month ago. But still doing it. And it's smokes alot when I put my foot down.
And that 280km is when I'm driving it normaly.....
Would you guys recomend buying a genuine Nissan O2 sensor for your make/model? Or just a replacement aftermarket part (made by a reputable brand)?
try giving your AFM a clean with electrical cleaner spray, they can get pretty dirty. Im looking at doing the same soon as my 32 is stock atm running 14psi and im only getting 400km on a factory tune, I would usually expect that with 240rwhp, not 185 which Im guessing I have
Edited by BANGN
May even be problem with the factory fuel reg that could explain the fuel usage. only take a pin hole in the Diaphragm
or a split Vac hose.
anyways good luck
 Share
