Parting Out R32 4 Door
Hi All,
had intentions of bringing back to a glamour, but, another car has come up that I want so instead of selling complete, I am parting it out as I am wanting to keep a few parts off it.
Item:
WHOLE car $6000 with stock seat, and front gtr brakes replaced with stock s14 brakes
OR
RB25 motor/box, brass button clutch, power fc with h/controller, wiring loom to suit R32 skyline, HKS 2540 turbo hks actuator, hks screamer pipe, front pipe FULL complete conversion ready to bolt in - $4000
OR
Rolling Shell with racing logic coilovers, adjustable front and rear arms, stock steering wheel, stock seat, no bodykit - $2500
Above three options need to know ASAP as car is being stripped TODAY so dont miss out on bargains
RB25 motor, brass button clutch, HKS2540 turbo, hks screamer pipe, wiring loom etc - $2200
Power FC w/hand controller suit RB25 NEO or R34 skyline serial no-PFCER34 010-0522 $1150
RB25 gearbox - $1600
1pce tailshaft suit rb25 R32 conversion - $300
Racing Logic coilovers - $800
KTS hicas lock bar - $80
Rear adjustable camber arms KTS - $100
Front castor rods D2 brand - $100
Nardi steering wheel 365mm, horn centre with detachable boss kit (came off HICAS 32) $250
Dildo gearknob $80
5 Stud conversion with s14 brakes (incl rear brakes, h/brake setup and h/brake cables) $950
Greddy Intercooler kit $300
Greddy oil cooler with sandwich, plate braided lines (one line needs replacing quote $95 to replace) $400
Shimmed diff 5 bolt - $80
HKS Screamer Pipe, 3' front pipe and 3' exhaust with cat, twin hotdog exit - $400
HKS Screamer Pipe ONLY - $220
Bodykit for 4 Dr 32 - rear bar usable, side skirts need attention, front bar well raped - $200
Cusco rear strut brace - $100
Tailights - $150
Headlights - $170
Bride seat rail - $80 (needs some tweaking with) seat not for sale as yet
Bonnet vented - $100 needs attention as pictures
Bonnet cut in middle - $50 require vent to look good
Complete doors, window, reg, locks, door trim, ready to bolt on - $100 each
Bootlid missing lock - $150
Rear screen with wiper motor etc - $200 REMOVE YOURSELF payment to be made BEFORE removal you break it, you bought it
Bare shell - $500 use to repair your own car
Logan
Website:
this
Item Condition:
All good
Reason for Selling:
another s14 on the way
Price and Payment Conditions:
refer to above for pricing - cash only NO SWAPS FOR ANYTHING
Extra Info:
car will be started to be stripped tuesday 19/5
PLEASE NOTE - more pics to be added during the week, car will be dismantled tuesday
Not wanting seperate too much that i've packaged together (eng, box, comp etc package) unless other items have interest or deposit - wanting to sell all together
Buy more then one thing at a time, will help out of prices.
Pictures:
detachable bosskit and pwr fc hand controller
screamer pipe off the hks2540 braided lines aswell
front bar (well raped)
bonnet (needs love)
engine bay pic how you see it, how you get it without intercooler or oilcooler (if want packaged can work out deal)
heat wrapped exh manifold
2540 turbo with braided lines
Nardi steering wheel with detachable boss kit 365mm
rear bar, tailights, bootlid, exhaust
rear bar
dildo gear knob
handcontroller
upclose on boss kit
lh side skirt has been cut for side exit exhaust
roof shot if interested in shell
rear bar/side shot
bride seat and rail
Contact Details:
PM or Call/SMS 0401 121 962
Got pics of the adjustable arms?
Intercooler - came out of a R32, there is NO difference in the eng bays between 2/4 dr - so YES it will fit
Gearbox - shift fine no problems at all, in whole rev range, no load and under load, haven't had a problem with it
Pics of adjustable arms up sunday.
A pillar plastic is in good condition
window switches are all working and good condition - but do have it on hold for somone atm - if fails, will be letting you know
PMs replied to - have been long time listener, first time caller, so haven't been able to reply to PMs as yet
hey mate, after stock seatbelts, heater coil, and windscreen if they are in good nick... pm if you have them and what you want for them
also might be interested in the rear strut brace and boss kit, depending how much you want for the rest...
CeJay - Ill get pic of A pillar trim, and also a quote on postage
HI2U - PMs replied to
32 Dave - PM replied
Jamo - Motor, gearbox and tailshaft etc will be missioning to get out sunday, if not will be removed 29/5 my next day off.
Fungus Mungus - stock seatbelts are fine, heater coil?? what do you mean, windscreen it will be cheaper for you to buy down your way, unless you are in QLD.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
