I'm bidding on that tomorrow. not for parts tho, for my own daily
So BACK OFF :sick:
wish me luck! does anyone know the history of the car?
Good Luck!
Besides the fact that it was stolen... I don't know any more than that
Edited by iamhe77
  • Replies 159
Will do,
can anyone tell me from the photos does it have the navi and all the bells?
Make sure you inspect it well. I've bought a few theft recovered vehicles and there could be significant stuff that you can't see. The crim could have driven it over kerbs, trashed the hell out of the motor or gearbox (they do that sort of s*#t to them). I'd be checking the underside and suspension. If you can start it that'd be good too (they will let you and sometimes help with a jump). Find the compliance plate too as you may have rego issues if it's gone.
From the looks of it it had an aftermarket stereo (face plate is not on), OEM didn't have removeable faceplate. It's got the screen but that doesn't neccesarily mean it'll work, if the DVD Rom was removed when they fitted the stereo it won't work at all.
Hopefully that wont be happening for a long while.. i've wanted a stagea for so long now!
Hope it has been worth the wait, they are a great car to drive that's for sure. I can't believe I was considering blowing masses of money on a new Holden Commodore Sportswagon.
I'm also glad I seen the Stagea before I went and brought a VZ second-hander too, I looked at a few but they no where near as good as a Stagea.
Hopefully we will catch up with you at the meet next month :(
I'm already shopping for new parts on Yahoo :blink:
will see how it goes, i need to sell the hilux before i think i can get this car registered/insured! i cant wait to take this on my trips to the snow!!
The Snow mode works a treat on the snow.
Yes, all the AWD ones do.
I used it getting into Hotham (which is at 1750m) in the middle of a blizzard after rain. so the road was icy and very slippery. But this mode made it easy as you don't get the boost coming on so quickly so it avoids all the excess torque as you keep the car going.
Cheers
Andy
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
