  • Replies 159
Just get another piece of plastic and superglue it in the same spot.
Most plastic models have plastic rods about the same diameter that are the waste part of the mold.
OR
if you are really keen, find the broken bit. I can bet that it was broken off whilst putting the console back in place and the broken piece will be some where around the place it is meant to locate.
Happy searching.
the front locating pin??
andy found out they mostly just fall out, but mine is broken and i wont be fixing it. it doesnt move all that much and personally it doesnt worry me all that much!
Yeah likewise, doesnt really bother me all that much, i do however need the knee storage for drivers side as when they ripped it apart they broke one of the tabs and it tore out a hole also.
the previous owner was a keen surfer. wax, fin tuning tools amoung other things i found.
There's drivers knee storage??
yeah those little pockets between your knee and the centre console. i keep a usb cable in mine for the charger in the lighter socket
:) duh of course. I was thinking maybe there was some sort of gloveboxy thing under the steering wheel or something. Never really think of the little pockets cause it looks like they were designed for a pack of ciggies.
ive noticed when i floor it off the line or accelerate harshly, things fall out of that place pretty easily. my mrs was putting her phone in the passenger side one till i gave the car a hit a few times and it landed under her feet each time :)
  • 3 weeks later...
Not sure if anyone has reaslied but this thing is back up for sale....
http://cgi.ebay.com.au/Damaged-Nissan-Stag...%3A1%7C294%3A50
I was wondering what he had done with it, thanks :(
That guy is dodgy, read the questions to the seller at the bottom of the ad.
As soon as someone asked the key question about weather it was an insurance write off or statutory write off he goes all difficult and avoids the question.
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
