  • Replies 159
What do you know about this car?
I saw it just over a week ago at a panel beater near my work. They had the front stripped to quote. They do all the high end $300K plus cars
I have a spare $160K at the moment, stuff the house reno's. It goes to auction on the 24th. I think I might have a look. . .
hey Mate, if your keen i can ask my brother tomorrow whats up with it and get a very honest description and whats up with it from him
pm me your mobile and i can get him to call you if he will.....
I will check with the panel shop tomorrow and see what they say.
Looks like it could be a flood car
I buy new car parts and slip them under the magic bench in the workshop, but a whole car might be a bit hard to get past the wife.
She said no more cars. I have built 3 others since that comment. What is one more....
Yee sweet as, let me know if you need to talk to my brother, i will let him know your keen anyway and to expect a call.
not sure if its a flood job, i asked him if there was any good flood cars the other day and he said no..
ohh someone should tell him there are no R35 skylines. meant to say that.
of course he had friends bid on it. whats the bet one of them accidently won and its listed next week because of 'non payment' or something similar
The only people stupid enough to bid on it were his mates or himself as you can see all of them have history with him and do you think the bidders names look alike or is it just me...
The names mean nothing anymore, they are randomly assigned but consistent to the same person.
How did you get all that history?
Cheers
Andy
You just log in and the info is there, you can see the same people bid on items off each other and give them perfect feed back, it is a way to build up your ratings.
thanks, found it. I thought it was a summary screen on all bidders then I realized you had put that shot together.
I would agree that the 2 highest bidders look a bit sus. But that said, good luck to them as it is not my money spent on that car. :P
Seriously, it would probably be less head f**k for the current owner to sell it to an import wrecker. Surely they would pay $5k for an M35 that has a fair number of good panels and a reasonable interior. It wouldn't be unreasonable to expect that the drivetrain is ok too.
:P
What a waste of everyone's time...
(but hey it kept us amused for a bit.) :blink:
A CPV35 with interior fire sold for $6,000 the other day here and we estimated it to be worth $3,500 to $4,000 due to the punt you are taking not knowing what is salvageable... It was seriously burnt but I forgot to get a picture.
pickles?
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
